Question about Polycom SoundStation 2W (2200-07800-001) Wireless Audio Conference
Base station How do you register with the base station
  • outgoing Feb 20, 2008
    i can't register the base station, it keeps saying registration failed.
    I tried holding down keys 1 4 9 but no lights flash.
  • voguegirl Mar 05, 2008
    I am having the same problem with the base not registering is there something else I can try?
  • 4 Answers
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
Posted on Nov 19, 2008
Ok, I had the same problem with no registering. I spent about 1 hour just doing it over and over. I tried everything 50 times. Suddenly on the 50th attempt it registered. Tested out fine and all. I cannot explain in any way other than welcome to the IT/Commo world.
Posted on Feb 22, 2009
If you can not connect to your base station, then you will need to have the phone serviced, about $200-300. You can buy another phone, or, as we did, another phone besides Polycom. The quality is not worth the price and the technology is poor. Our phone failed twice in less than a year.
Posted on Sep 25, 2008
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
Posted on Nov 28, 2007
Registering Handset to Base Station
Registering the handset to the base station has nothing to do with your wireless router. The handset and the base act like walkie talkies. The signal from the handset must match the signal in the base station. The handset may have a reset button of its own, or a sequence you must go through to register the handset to the base. Try removing the battery from the handset and see if that will work. If not you need the manual to tell you what to do to register the hand set to the base.
Dec 12, 2017 | RTX DUALphone 3088 for Skype
I cannot register the handsets to the new base station I had an 8100-2 base that quit working. I bought a new 8100-1 base. Can I change the MAC ID on the phones so they will accept the new base station?
If you cannot register the handset then here are some possible causes and solutions for them.
Cause 1:The handset and the base station were not prepared for registration.
Solution: Unplug and then plug in the power adapter.
Cause2:The handset or the base station has not been entered into registration mode.
Solution: See User Manual for correct registration of base station and handset.
Cause3:The base station is registered full.
Solution: Press [Page Key] on the base station to page the registered handsets, then perform the deregistration operation. Finally, register the handset you want to use.
Here is few more of additional info. if you want:
Register the Handset to the Base Step 1:
Place the accessory handset in the base station of the system. For some simple systems this may be all you need to do to register the new handset. If so, the LCD screen will read "Registration Complete."
Step 2:
Press the "menu" button on the base station, scroll down to "register handset" and press "ok."
Step 3:
Press and hold either "#" or "OK" (depending on the brand) on your handset until your hear the indicator tone. At this time the LCD should confirm the handset is registered.
Reset Handsets with the Base Step 1:
Clear the registration information from the base if you want to register your handset to a new base.
Step 2:
Hold [] and [#] down on the base for a minimum of 5 seconds or until the "System Reset" menu appears.
Step 3:
Choose the "deregister" option from the menu and scroll down to the handset you wish to remove.
Step 4:
Press "OK" to de-register the correct handset. Press "yes" when you are asked if you are sure, and wait for the confirmation tone.
Reset Handsets without the Base Step 1:
Hold [] and [#] down on the phone for a minimum of 5 seconds until the "System Reset" menu appears.
Step 2:
Choose the "base unavailable" menu, select "yes" and press the "OK" button.
Goodluck,
Please don't forget to rate the solution.
Mar 21, 2008 | Vtech IP 811 Cordless Phone
The phone says no phone line, and i dont have a dial tone. cant call out and cant get calls coming in
Model LS6305: How to register a handset:
  1. Place the non-registered handset in the telephone base or charger. If 1.Press FIND HS on base 4sec and 2.Then press # on handset do not appear alternately on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds until the red IN USE light on the telephone base turns on.
  3. Remove the handset from the telephone base or charger and then press # (pound key). It displays Registering...Please wait. It takes about 60 seconds to complete the registration. The handset displays Handset X Registered and you hear a beep when the registration process completes.
  • If the registration fails, the handset displays Registration failed for a few seconds, then 1.Press FIND HS on base 4sec and 2.Then press # on handset alternately. To reset the handset, remove it from the telephone base or charger and place it back in. Try the registration process again.
Model ip8300: How to register a handset:
  1. Press and hold FIND HANDSET for at least 10 seconds on the telephone base. The VMWI and LINE IN USE lights will blink alternately indicating that the telephone base is in registration mode.
  2. To display the telephone feature menu, press the Menu softkey from the main idle screen.
  3. Press the up, down, left and/or right NavKeys to choose Registration Settings then press the Select softkey or center NavKey/SEL.
  4. Press the up or down NavKey to choose Handset Settings then press the Select softkey or center NavKey/SEL.
  5. Press the up or down NavKey to choose Register to Base then press the Select softkey or center NavKey/SEL. A list of locations for assigning telephone bases will be displayed.
  6. Press the up or down NavKey to choose an empty location and press the Register softkey or center NavKey/SEL.
  7. The handset will display Searching while it searches for the telephone base. If the search is successful, a code from the telephone base will be displayed. To register the handset to the telephone base, press the Register softkey.
  8. In the Enter PIN box, enter the system PIN. The default PIN is 0000. Press the Apply softkey.
  9. Handset registered will be displayed when the registration process is complete. The screen will return to the registration settings menu. Press OFF to return to the idle screen.
Model ip8301: How to register a handset:
  • Before registering the handset with the base station, press the FIND HANDSET button in the base till the VMWI and LINE IN USE lights blink alternatively. When the lights start blinking, register the handset. The default PIN for registering the handset with the base station is 0000.
  1. Press Softkey Menu from Home screen
  2. Choose the Settings icon from Menu screen and press center Navigation key/SEL to display the settings menu options.
  3. Press the up or down Navigation Key to choose the Registration Settings menu option and press the center Navigation key/SEL to select.
  4. Press the up or down Navigation Key to choose the Handset Settings and press the softkey Select to select.
  5. Press the up or down Navigation Key to choose the Register to Base and press the softkey Select to display a list of available base stations. Choose a base station from the list and press the softkey Select to select.
  6. The handset will search for the Base within its range. During this time, the searching screen will be displayed.
  7. If the search is successful, the Base station number of the base will be displayed.
  8. Press softkey Register. Enter the PIN and press softkey Apply to save and subscribe to the base station.
  9. To cancel the entire operation, press OFF key anytime.
Mar 07, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
How to reboot soundstation 2w polycom if you forgot the password
egistering Base Station on Polycom SoundStation 2W
OR
1. press menu key
Mar 05, 2010 | Polycom SoundStation 2W (2200-07800-001)...
I have the swatch cordless II phone with base station however I have lost the instruction manual for the base station and therefore cannot register the handset with the base station. Has anyone got a...
To register a handset with Cordless 2 base: Keep pressing call button [loudspeaker icon] on base for 5sec. then press [right pointing arrow in a diamond] twice. Then 9 0 1 then the system PIN if required. Choose internal number 1 to 6 for this handset and then the designation of the base station A=2, B=5, C=8, D=0, followed by [right pointing arrow in a diamond].
Hope that helps!
Jan 17, 2010 | Lands Phones
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
Olympia cdp24201
1. go to menu, then HS setting, then registration, register
2. follow the steps and register the set to the base.
3.press and hold the base mute button for 10 seconds, press next to continued
4.select the cbs and connect it.
5.enter 0000 as a password
Jun 28, 2008 | Olympia CDP 24201 Cordless Phone
Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Feb 02, 2008 | Siemens Gigaset 2415 Cordless Phone
TWX977 submersible unable to base register
push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Sep 09, 2007 | Uniden TRU9485 Cordless Phone
Polycom SoundStation 2W (2200-07800-001) Wireless Audio Conference Logo
3,321 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
