Need a toshiba dvd combo recorder manual DVR-5SU
Assistance to fix my toshiba dvd combo recorder manual for satellite installation my problem is i know nothing on fix more then one system and haven't the manual  for  that  recorder  how  i can  get  this  manual
    Habit-Forming:
  • 188 Answers
MAN
I M SURE I CAN HELP U
WWW.GOOGLE.COM
CAN HALP U
JUST TRY THIS LINK..
www.KitchenManuals.com
best regards & best of luck..
Posted on Oct 12, 2007
  • SHIVAJI YADAV
    SHIVAJI YADAV Nov 06, 2007
    hey dude.....u did not make any repley....for u r problem solution ...
    hope it is solved.......
    Was this solution helpful? Show your Appreciation by rating it:
    pls vote for me man..& IF U R PROBLEM IS SOLVED RATE MY SOLUTION AS SOLVED
  • SHIVAJI YADAV
SOURCE:
Need instructions and codes for toshiba t.v.
Hello
Codes for Toshiba TV with One for all URC 4220 are:
0060, 0154, 0156, 1265
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insertmedia (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume,andVCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4]Use the Manufacturer's Codes to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again
[5] Aimthe remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
OK.
Jul 03, 2011 | One For All URC4220 Remote Control
Since change over to digital dvd/vcr Toshiba SD-37VB does not record on Video tapes. What do I need to do to correct this or do I need to purchase some additional unit?
Subcribe to cable or satellite tv services.Ur dvd/vcr unit will able to be used to record on VHS tapes again.Because cable or satellite tv services the tv incomming broadcasting tv signal still do broadcasting comming in as analog tv signal for the analog devices as analog devices require as it needed.
Apr 27, 2011 | Toshiba SD37VB DVD Player / VCR Combo
Do you know where I could find and print set up directions for a Toshiba LCD TV DVD Combo. 19LV61
I have been able to find a manual for a 19LV610U and 19LV611U.
You could try this out from the Toshiba website.
Here is the link:
http://www.tacp.toshiba.com/tacpassets-images/models/19lv61k/docs/19lv61k_om_e.pdf
I hope this help you with your search, if not please respond to this post and I will be happy to help you further.
Thanks for using FixYa
asnowman
Oct 23, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Trying to record from TV.
TRY HOOKING THE COAX TO THE DVD RECORDER THEN TO THE TV ,BEST I COULD THINK OF.
Mar 27, 2009 | Cyberhome DVR 1600 DVD Recorder
Cannot record from my DirectTV DVR, HR20-700
most dvr units froim cable and satellite companies use a type of copy protection that does not allow you to copy programs to a disc. the cable company wont tell you this but they do and there isnt any way to work around it
Mar 11, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Dish Network remote code for RCA 20F510TD TV/DVD
hello and please help.
want to know the codes and way to program this rca dish remote model RCR500SAM1 for my Toshiba tv.
ive done it a few years ago but forgot.
so i need the codes for toshiba tv and way to program this rca dish network remote.
grateful,
kay
Jul 26, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Toshiba dvd/vcr combo
how can i explane it the dvd recorder has its own built in format that stops other dvd players from playing the discs in them they also dont work on the pc either ive tried
Feb 17, 2008 | Televison & Video
URC-3021B00
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
selection, volume, and DVD functions.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
the same code again.
5. Aim the remote control at the device and press POWER
you find one that works. If it still doesn’t work, try
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Nov 26, 2007 | One For All URC-3021 Remote Control
96 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
