Question about York Yankees Bedding MLB Comforter
Installation manual for York Affinity Series Furnace
Affinity 9.s, York furnace, 4 blinking red light/code, changed filter, doesn't reach requested temp. and stops.
Well change filter but if filter is clean you might have a restriction on your return vent.
Make sure vent is clear
Dec 26, 2017 | Heating & Cooling
York affinity 9.s series, year 2008. I have not used my furnace since last winter (approximately 7 months ago). I went to start it up this year for the first time and it will not start. Upon inspecting...
Fuses will blow if there is an overload.
Breakers only trip if there is a short to ground.
Since you replaced the fuse and it blew and tripped the breaker , I would check for a wire problem. Also check the elements that rodents haven't built nests ect...
Nov 12, 2014 | Heating & Cooling
Can't get the gas furnace to heat.
All York/JCI thermostats made by Venstar
The setup is probably incomplete. Did you configure the thermostat for a 2 stage heat pump? The heat pump should have a thermostat wire connected to R, C, Y1, Y2, and O, that makes 5 wires. I suspect you are only using first stage compression and or first stage blower speed.
Nov 23, 2013 | Source1 CTS Series Model S1-THPU32P7S...
Where can i purchase filter for a york furnace affinity yp9c080c116mp11? looks like 20x25x5 accordian type. Home depot--lowe's. What is the model number?
you should be able to find that filter size at either store if not search air bear that should get you thte right size filter
Jun 12, 2010 | Heating & Cooling
York affinity heat pump installation manual
Go to WWW.YorkUPG.com and search for your model. Should be in the downloads section
Aug 28, 2009 | Heating & Cooling
INSTALLATION MANUAL FOR PV9C YORK FURNACE
I just replaced a thermostat on a york furnace model gy9s100c16up11h. During the process i connected the red and white wire and the unit came on after making the connections it will not come on even if I jump the red and white wires without the thermostat. Thanks Dan
Jun 10, 2009 | Heating & Cooling
TH8320U1008VisionPro8000 honeywell thermostat with Affinity York
Take a multimeter and check your rh and w terminals. With the face off, you should get 24 volts. If you do not get 24 volts, turn the power off, and check the continuity, you should get ol (open load). Now if you do not have 24 volts, and the meter reads ol, there is a problem in the wiring to the thermostat. My only concern is the green light blinking slowly, but if that is normal on your unit, I will let it be. Hope this helps
Mar 24, 2009 | Honeywell CT3600 7 Day Electronic...
Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
Jan 16, 2009 | York Yankees Bedding MLB Comforter
Owners Manual
York Corporate Headquarters
631 South Richland Ave.
York, PA 17403
Phone: (717) 771-7890
Contacting York
Mail:
York International Corp.
P.O. Box 1592
York, PA 17405-1592
USA
Phone: (877) 874-7378
York Website
York was purchased by Johnson Controls in 2005
Johnson Website.
I cannot find an actual manual online. I hope this information helps you. Good Luck.
Dec 27, 2008 | York Yankees Bedding MLB Comforter
York Yankees Bedding MLB Comforter Logo
1,178 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
obsteiner
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
