Hello Shannon,
The issue may be there may be some driver missing or hardware problem, Follow the below steps to confirm whether its an hardware issue or a software issue.
1. Right Click on My Computer and click on Manage.
2. Then Click Device Manager from left side pane and see whether do you have any Yellow Mark appearing. Which means drivers are missing for your camera else see whether you can see the integrated camera in the Camera section.
Thanks!
SOURCE: USB not decting plug n play devices
I would check the bios settings to make sure the motherboard settings relating to PnP are correct. Try playing around with those bios settings and see what works for you. Also try different usb ports, i have the same problems sometimes with certain ports on my desktop computer, try all of them at the front or the back of the computer. I would check the Compaq Presario website for drivers not AMD, installing new ones is a good idea just to make sure its not a driver issue.
SOURCE: Hi, i have a cyberlink
Yes Vista is the Operating System. From what I have been able to determine you need YouCam 2 for Vista. You can check with Cyberlink to see if you qualify for a free upgrade or fix for this problem. You will find the support for your Youcam at Cyberlink here: http://www.cyberlink.com/multi/products/main_125_ENU.html
SOURCE: Problem with integrated webcan Lenovo 3000 N100 notebook
Buy external webcam; troubleshoot this problem was westing our time.
SOURCE: My Dell Inspiron 1525 integrated camera won't connect
please try to uninstall your webcam and again reinstall it coz your webcam driver is accidentally corrupted. hope this will solve your problem.
SOURCE: I have a lenovo 3000 N 100 HBQ 0768 notebook which
try restoring to an earlier time when it did if this works its probably viral or software corrupted
Your computer may include an
integrated webcam, located at the top of the display. The webcam is an input
device that allows you to capture and share video. Preinstalled CyberLink YouCam
software provides new features that expand the webcam experience.
To use the webcam and CyberLink
YouCam software, select Start > All
Programs > CyberLink YouCam >
CyberLink YouCam.
NOTE:
The first time you access the YouCam software, you may experience a brief
delay as the software loads.
Using YouCam as your default webcam
software enables you to experiment with the following features:
Video-Record and play back webcam video. You
can also e-mail or upload video to YouTube, using the icon on the software
interface.
Streaming video-When you open your instant
message program, YouCam displays a floating toolbar that lets you add graphic
effects.
Special effects-Add frames, filters, and
emoticons to your snapshots and video.
Snapshots-Take single frame or "burst" webcam
shots in rapid succession.
Connect-E-mail photos and video using the icon
on the software interface.
NOTE:
For details about using webcam software, refer to the software manufacturer's
instructions, which may be provided with the software, on disc, or on the
manufacturer's Web site.
