Question about Car Audio & Video
Need to know how to wire the speaker mono?
Can't remember how to wire a jensen a220 amp.not sure how to run the speaker wires to bridge it mono
  • jsinsorrow May 11, 2010
    Is it a 2 channel amp? if so than hook the speaker wires together (positive to positive and negative to negative) and hook both positive to + on one channel and negative to - on the other channel.
  • Anonymous Mar 23, 2014
    have a jensen deck with rca out have amp with speaker wir input scosche wor and how do wire that
    Problem Solver:
  • 7 Answers
Bridge should be made positive left channel + negitive into - right channel but make sure the amp can take the speaker impedance load or you will trip the amp or cook it if you over load it.
PW NW You may also need a choke for correct frequencey response
Posted on May 30, 2009
I have power to my Jensen 400 watt amp. But no
It's possible the output stage(s) of the amp are blown. Check all audio wiring connections to the amp, input and output, to make sure nothing is loose or disconnected. Also, try wiring up a different sub to verify it isn't the sub that's bad.
Aug 28, 2014 | Car Audio & Video
JL Audio Amp. My amp all of the sudden started cutting in and out. It's an older amp and I've never had issues with it before. I've checked all the wiring and the fuse it all seems fine. Any...
you need to determine what impedance the amp is running at ,how many spekers ,most 2 channel amps will only run 2 4 ohm subs per channel and only 1 4 ohm speaker in bridge ,Basically if you have 2 4 ohm speakers bridged at the amp it will usually cut in and out .Some amps will not do this for a while and will work for a while at low impedance but once they get older and hot and cool off many times they will then only work for the intended ohm load ,Do you have 2 speakers ,if so make sure 1 is on left channel and 1 is on 2nd channel (should not cut off ) if it is a mono amp ,make sure you are only running 2 4 ohm subs and not dvc speakers (these will run 1 ohm and shut the amp down ) there are ways of wiring more speakers or dvc speakers ,I can explain but I need to know what product you have .
May 07, 2012 | Car Audio & Video
How do i bridge my jensen 200 watt amp? its a 2 channel bridgeable.
Easy, you grab a dual wire cable (like the one in the back of your amp that runs to the speaker) and stick each wire on one end to the positives on your amp. Then, on the other end, twist both wires together to form one wire. Hook it into your positive connection on the sub(s). Repeat on negative side.
Aug 09, 2010 | Jensen Car Audio & Video
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
Dont know how to wire a subwoofer
The Jensen XS1010 is a 4-ohm sub and should work properly off of the outputs of most any single channel monoblock sub amp or off a bridged 2-channel. You did not say what brand or type of amp you intend to use, but in any case, there's only 2 wires to connect to the sub, one positive (+) , the other negative (-). Simply match them up with the positive and negative on the amp speaker output and you are ready to bump.
Here's the link to Jensen's website:
http://mobile.jensen.com/jensen/
I'd recommend downloading the XS1010 manual. They recommend an enclosure with at least .75 CuFt internal volume.
If this helps, please rate it as "FixYa". Thanks!
Mar 28, 2009 | Jensen XS-1010 Car Subwoofer
Wiring Diagram
i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
Jul 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Hooking Up A Sony XM754HX To Jensen BP210
hi .let me see if i can help u out ...need more info on the speaker..are the 8ohm or 4ohm ? and are the single are DVC?.....from what i can see u can bridged the amp..and u must connet the subs in series or just connet each sub +/- to +/-..and that will give u a stereo mode... u will still get great sound
Jun 21, 2008 | Sony XM-754HX Car Audio Amplifier
JBL Sub Amp Wiring Please
it seems rather redundant to bridge a mono amp. Unless the instruction manual states otherwise, i would assume that one speaker output is identical to the other (ran in parallel, like an A or B speaker, not like Left or Right), and you would present the amp with a two ohm load by wiring one speaker to each output. Bridging it may or may not work, but, again, it just seems redundant.
Mar 01, 2008 | Car Audio & Video
Mono wiring
leave rca as it is,only speaker config is needed there should be an illustration printed beside the connectors that says bridge
Aug 08, 2007 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Car Audio & Video Logo
205 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
