Question about GE GTS22KBP Top Freezer Refrigerator
GE refridge temp control makes clicking noise
Model GTS18KCPJRWW - the temp control unit makes periodic clicking noise when the compressor runs. What is the source of the noise? Is some part malfunctioning? Refridge operation seems normal otherwise.
  • 62 Answers
Probably a few loose ends causing the rattle sounds it does it for most fridges.
Posted on May 11, 2009
Our GE Profile refridge stopped working and all of the food getting warm. The model number is: Psw26sgrbss. What do we do?
controls inop.? replace main control. is compressor running and controls responsive? then check for defrost problem. comp ok but no frost either then sealed system problem.
Sep 14, 2012 | GE Refrigerators
Ge profile refigerator /bottom freezer. Power in area had gone out . with power restored fridge tries to start, but then you hear a clickink noise, like a relay going on and off. The temp control readout...
First of all, the clicking noise could be the overload relay on the compressor. Secondly, the temperatures have me concerned for they should not be in the negative number. Verify the compressor issue first, put your hand on the compressor, check to see if its running or if its warm to the touch.
I also need a model number to direct you further to parts and other issues.
Aug 28, 2011 | GE Refrigerators
Hello I have a GE lower freezer model # PDS22SBSARSS AND THE TEMP CONTROL is clicking and the digital readout is doing weird things by indicating wrong temperature and clicking, it stops after awhile...
Roll the refrig out and determine where the clicking noise is comming from. If it is form the small rectangular cover on back, replace the main board (WR55X10942) located under it. If the clicking is comming from the compressor area (at the very bottom, behind the cover which goes all the way across the bottom of the refrig) then replace the relay (WR07X10086) and overload (WR08X10061) located where the wires attach to the compressor, and for good measure, the capacitor (WR62X79 ). (located just to the left of the compressor)
Jan 12, 2011 | GE Profile PDS22MHR Bottom Freezer...
I have a kenmore s x s refridge and the freezer is cool by everthing is thawing out. I hear a clicking noise so I took the back cover off and it seems to be coming from the compressor.
the clicking noise may be coming from the start and oveer load relay on the compressor shut the unit down until the compressor is cool replace the over load and start relay on the compressor.
if you have a clamp type power metercheck the current draw on the compressor it should be between 1.2-1.6 amps during a running load.
May 19, 2010 | Kenmore Refrigerators
Ge Zoneline heatpump works fine in the summer but in the winter with 45 to 50 degree days the compresser hardly runs. By turning the thremostate you can get it to run for a short period. I have 6 of these...
These Ge Zonelines have and ambiant Temp control on the unit when the temp drops it drops out the compressor and goes to electric heat. This keeps the unit from getting iced up. They do go bad and sometimes they shut off to soon. I just replace them and everything goes back to normal. They are located on the outside part of the unit. Just slide out the unit and it is located I beleive on the right side of unit Rus.
Dec 17, 2009 | Humidifiers
I remplaced the relay from the compressor but the frig dont turn on only make a klick noise on the power board
you need to replace the electronic control board where your hearing the clicking noise its bad,this is common for this unit model
Dec 14, 2009 | GE Profile PSS29NGS Side by Side...
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Refrigerators
I have a GE REfridge that stopped running....
The compressor never runs out of freon - unless you have a leak somewhere, which is rare - and besides, your compressor motor would be still running but you would not get cooling - the most common problem associated with this is control board failure, so compressor does not start at all. Try unplugging the refrigerator for a few minutes and plug in again - see if this resets the control board - if problem persists or comes back you will need to call service and have them check the control board.
Before doing so, try unplugging and plugging back in after a few minutes, it might get things started again - if you have a manual knob for your cold control try setting the dial to off, then turn it back on all the way until you hear a "click" sound to confirm your thermostat is working properly - if you hear the clicking on the thermostat area, but compressor motor does not come on, call service.
Sep 04, 2009 | GE GSS20IEP Side by Side Refrigerator
My compressor it not comming on On the circuit board I Jump line to comp but still nothing could the compressor be bad
either its not getting its juice or the relay is bad doubt it could be the compressor but it does happen
Jun 24, 2009 | GE GSS25LGM Side by Side Refrigerator
Ge ref. making clicking noise not running display not working
Replace the main board on the back my was about a $130 at a wholesale parts store and i put it in
Jan 17, 2009 | GE GSH25JFR Side by Side Refrigerator
GE GTS22KBP Top Freezer Refrigerator Logo
280 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
