Question about Canon PIXMA MP160 All-In-One Printer
Error 5100, "E", "2" flashing in display
Printer worked fine yesterday, now getting a 5100 error. Flashing yellow alarm light, and "E" "2" in the display
  • doshorses May 11, 2009
    Paper is not jammed, and powered off the printer to reset it. When powered on at first, the cartridges move one side to the other, but then makes a loud click noise. There's nothing foriegn inside, but I'm wondering if the color cartridge is hanging on some part.
  • 4,041 Answers
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Says E on LCD with a flashing 2 and alarm light Canon Pixma MP150 Error Code 5100
Either you replaced your printer cartridge or your ink is over or there seems to be a paper jam.
I have a Conon MP160,I got the same error when I got my Cartridge re-filled by a local re-filler,but the printer works fine.
Go to Printer Maintainance(Click the Printer Settings Wizard on Control Panel),all your problems get resolved there
Thank You.
Feb 13, 2011 | Canon Office Equipment & Supplies
Error 5100 on/off flashing and alarm flashing
Hello
Remove the error code 5100 1. Turn off printer. 2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work!
Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
Dec 31, 2010 | Canon Pixma MP450 All-In-One InkJet...
Error code 5100 displayed with orange alarm and green on off buttons flashing on and off
According to the manual, Error message 5100 indicates: "Movement of the FINE Cartridge Holder is blocked. Open the printer
and make sure there is no little piece of paper or other
object keeping it from moving. Unplug the printer.Then disconnect the printer f
from the computer. Plug it back in and try it again.
Aug 11, 2010 | Canon Office Equipment & Supplies
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
How to correct error 5100 in canon pixima ip 1800 prnter
Hi You can Try
If you still look at this web then have a go
Error Code 5100
Solution 1:
Solution 2:
Sep 27, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cannot get Canon PIXMA MP 150 to work at all
salve la mia mi canon mp 150 lo scanner non funziona e mi da errore code 2,250,0
Apr 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon printer pixma ip6220D is showing error code 9000 alarm light flashing. What to do please?
Canon printer pixma ip6220D is showing error code 5100 and alarm light flashing. Help me how to repair it?
Dec 21, 2007 | Canon PIXMA iP6220D InkJet Photo Printer
Canon PIXMA  MP160 All-In-One Printer Logo
78 people viewed this question
old marine
old marine
