Question about Dell OptiPlex GX400 (2090246019) PC Desktop
My dell gx 400 when i turn it on it only beeps and nothing happen
It only beeps and
Open it up and vacuum it out. then it should be ok
Posted on May 11, 2009
Dell XPS PC Desktops Beep 2 short beeps then turns off
Here is a link to your computer's service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_xps_desktop/xps-400_Service%20Manual_en-us.pdf
There is a section on Advanced trouble shooting which details Beep codes and LED diagnostic codes.
Feb 13, 2013 | Dell XPS Computers & Internet
Dell optiplex gx 280 beeps 6 times when turnd on and nothing happens
The ram is either bad or unseated. Reme it all and reseat it. If that doesn't work, boot after adding each stick to find which stick or slot is bad.
Nov 11, 2012 | Dell Computers & Internet
I have dell optiplex gx 150 beeps 6 times and a and b led is amber and c and d led is green
the 6 beep codes will be in a specific timing i.e. two beeps, a space 2 more beeps, and another space and 2 more beeps.
Looks like it may be a memory problem according to the lights.
ad54556.gif Possible memory failure
Reseat all DIMMs and restart the system to retest.
Here is the link to the beep codes and diagnostic lights for your dell optiplex gx 150 HERE
The Beep codes are in Table 2 and the diagnostic lights are in Table 3.
Apr 14, 2010 | Dell Computers & Internet
Dell gx 400, ati rage agp card died, installed ati pro pci in my other GX 400 just to see if it would work. Won't work in GX 400 at all. Wonder why? What video card will work?
hello, the documentation says agp 2 or 4 times agp. you can buy an ati radeon, these agp cards are inexpensive these days. you can get one that has dual monitor support, around 50 bucks. this is what i would do, and loose the pci video card this link is the documentation. good luck! please rate this solution. and if you need further assistance, reply http://support.dell.com/edocs/systems/opgx400/en/UG/index.htm
Apr 23, 2009 | Intel Pentium 4 1.8GHz 400MHZ 478pin 512K...
My dell dimension 2400 beeps morse code like and won't load
you have to follow the beeps very well to understand wat is the problem, each type of beep gives you sign for problem. so check if its one beep, two, or three, short or long, this makes very easy to you to define the problem.
Try to take out that parallel port if your pc works fine, this means this connector was not compitable to your board.
Best regards
Feb 28, 2009 | Dell Dimension 2400 PC Desktop
My dell gx 280 just put new ram
Here is the code,Please make sure the memory you used is DDR2 and please rate this a fixya
Feb 14, 2009 | Dell OptiPlex GX280 PC Desktop
Dell optiplex Gx 150
This is a problem with your memory.
During POST, the computer checks the computer's memory, determines the amount of installed memory, and then writes to and reads from the number of available bytes to ensure proper operation.
Basic Checks:
  • If an insufficient memory message appears, save and close any open files and exit any open application programs not in use.
  • Consider installing additional system memory.
  • Run the System Memory test in the Dell Diagnostics.
  • Reseat the memory modules.
  • Restart the computer.
If the problem still exists after you complete the basic checks, fill out the Diagnostic Checklist as you perform the following steps.
caution.gif CAUTION: Before you perform this procedure, see "Safety Information."
  1. Reboot the computer.
Does the RAM count displayed correctly match the actual amount of memory installed in the computer?
Yes. The computer needed to update the memory count. The problem is resolved.
No. Go to step 2.
  1. Run the System Memory test group in the Dell Diagnostics.
Did any of the diagnostics tests fail?
Yes. Contact Dell for technical assistance.
No. Go to step 3.
  1. Turn off the computer and peripherals, disconnect them from their electrical outlets, wait at least 5 seconds, and then open the computer cover.
  2. Rotate the power supply away from the system board.
  3. Replace the memory module(s).
  4. Close the computer cover, reconnect the computer and peripherals to their electrical outlets, and turn them on.
Yes. The memory module(s) were defective. The problem is resolved.
No. Contact Dell for technical assistance.
Nov 06, 2007 | Dell OptiPlex GX260 PC Desktop
Dell gx 150
Chuck,
The 6 beeps are an error code. You should note a pattern such as 3 beeps, short pause, 1 beep, short pause, 2 beeps. Also, you may have a set of 4 error indicators on the back of the unit that will show a pattern of green and yellow lights. In any case, you will want to try to run the Dell diagnostics. Let us know the beep pattern and the light pattern and we should be able to give you some more specific information.
R-
Nov 05, 2007 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX400 (2090246019) PC Desktop Logo
132 people viewed this question
Alun Cox
