Question about Garden
Lawnmower stopped working
I was cutting the grass last week and my Black and decker electric lawnmower (lawnhog) suddenly stopped working. I check the power cord, but nothing was wrong. It will not start up. What could be wrong?
  • Anonymous May 24, 2009
    I have the same problem. Were you able to rectify your problem?
  • 313 Answers
SOURCE: Black & Decker 18" Electric Lawnmower not getting any power
open up the top cover of the mower & inspect the armature commutator & brushed if not broken.also checked for loose connection on the rectifier,extension terminal on the switch handle then the switch the last to checked ig any burnt on the terninals too. this are common probel may occur if mower not running.
Posted on Jul 19, 2008
  • 9 Answers
SOURCE: Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Posted on Jul 30, 2008
  • 121 Answers
SOURCE: black and decker corded lawnmower barely runs
It sounds like you have a loose connection somewhere in the motor
Posted on Sep 27, 2008
boscia
  • 163 Answers
SOURCE: petrol lawnmower cutting out.
try changing the spark plug. if that doesnt work check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal.
Posted on Nov 29, 2008
darth yoda
  • 4 Answers
SOURCE: Motor runs but base doesn't spin to do the trimming. How can I fix this? I have a Black & Decker 14 inch Grass hog- electric trimmer.
gearbox!! get rid of it
Posted on May 29, 2009
When i start cutting grass for few minutes my lawnmower will trip the house breaker that is a problem
You may have an electrical circuit you are plugged into that has too many things running on it. Like appliances etc. To run an electric mower you should have a separate line right from the electrical panel as the mower does draw a lot of power. Most older homes are not wired to run these things. Sometimes a person will hook into a receptacle closest to the outside where they want the hydro run outside and they do not know what all is on that line.
Feb 18, 2014 | Black & Decker 19" Electric Lawnhog...
I tried to mow the grass even though it rained this am. our grass was really high and i saw a little smoke come out of the lawnmower. is that because the grass was still a little wet or the grass was...
Nope. If the grass is too high, knock it down to size with a weedeater first. These electric mowers cannot handle the tall, high stuff. If you do, you will surely burn it up.
Aug 14, 2011 | Black & Decker 18", 6.5a Electric Mower
Black and decker corded lawnmower barely runs
Sep 25, 2008 | Black & Decker 19" Electric Lawnhog...
Jul 19, 2008 | Black & Decker 19" Electric Lawnhog...
Removal of blade from black & decker lawn mower gx530
i used impact gun with 3<4 socket and run the impact in reverse
May 26, 2008 | Black & Decker 19" Electric Lawnhog...
MM875 electric lawnmower
check motor if armature are not broken & see if the rectifier not burnt. rectifier works from ac & convert it to dc to run the motor.
if you need diagram for parts see toolpartsdirect.com
Aug 27, 2007 | Black & Decker 19" Electric Lawnhog...
Garden Logo
301 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
