Wi-fi take long to connect
I have a dlink dir-615 router and when i start up my laptop (dell studio 15 inch) it take long to connect and identify my network. I have a WPA2-PSK security key. What can i check to make the connection faster?
  • exterra1 May 11, 2009
    thanks ill try that
    Sergeant:
    Novelist:
  • 197 Answers
You can try reconfiguring your router to WEP security, that should establish a connection quickly.
Posted on May 11, 2009
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
How to set a password for the dlink dir 615 after set up
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 or 10.1.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
thanks for choosing www.fixya.com and kindly rate this post.
Jan 03, 2012 | D-Link DIR-615 Wireless Router
How do I reinstall a dlink 615 modem. mcafee syys a trojan has been identified each time I try the install disc. can I install without the disc and how?
I can help you with your DLink DIR-615 router problem.
You don't really need to run anything from the disc to install a router - there is no setup program on the dlink cd you are required to run. Routers operate independently of the computers they are plugged into.
The most useful thing on that disc is the user manual, which you can download direct from DLink here. Any other bits and pieces that are on the 'installation CD' are also available from their webpage.
I hope that helps.
Aug 28, 2010 | D-Link DIR-615 Wireless Router
Unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
Jun 17, 2010 | D-Link DIR-825 Wireless QuadBand Router
I have 2 laptops one is dell and one toshiba. I installed new router dlink 615 and I am connected on toshiba but not with dell. What might be the problem?
Check for the IP settings, ensure that they are in sync with the settings of your router. For example, setup your computer to use automatically provided IP if your router assigns one; otherwise else push a manual/static IP.
Feb 02, 2010 | D-Link DIR-615 Wireless Router
Hi. I just configured a DLink DIR-300 wireless router on my laptop. During the installation, it required me to keep the ethernet cable connected between the router & the laptop. I finished the...
First you have to check on your laptop that your wi fi network drivers are installed correctly.
Also check it is enabled.
Also check wi fi switch on laptop is turn on.
Check its ip addreses and subnet amsk and gateway is proeprly.
Aug 19, 2009 | D-Link DIR-300 Wireless Router
Computers & Internet Logo
236 people viewed this question
David Payne
David Payne
