Question about Whirlpool LER5636P Electric Dryer
WHIRLPOOL DRYER IS TESING 9.6, WHAT DO WE DO. THE DRYER WORKS BUT WILL NOT HEAT
  • Whirlpool Master
  • 43,501 Answers
Hi, If you have a gas dryerWHIRLPOOL DRYER IS TESING 9.6, WHAT DO WE DO. THE - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
dryer is electric2_bing.gifDryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 29, 2010
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Why is there no heat and no timer operation?
Whirlpool & Kenmore Dryer Repair - How To Diagnose No ...
? 9:01
www.youtube.com/watch?v=JfXBiZOiC2Q
Nov 3, 2011 - Uploaded by canyonman1963 Whirlpool & Kenmore Dryer Repair - How To Diagnose No Heat - High Temp Fuse 279816 OR 279769 Test. canyonman1963.
Aug 19, 2015 | Whirlpool Dryers
I have a Whirlpool Gold Senseon electric dryer that will run but does not heat. When the dryer is started it will remain in the "sensing" cycle for 9-10 minutes then jump to the cooldown cycle.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Sep 19, 2011 | Whirlpool LER4634J Electric Dryer
Dryer not heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 29, 2011 | Whirlpool LEB6200 Electric Dryer
MYDRYER DOESN'T HEAT UP. IT WORKS ONCE AND THEN WON'T HEAT UP AGAIN FOR 9 OR 10 ATTEMPTS.
Here is a tip that will help you...
be sure to also check out the tips at the bottom depending onif you have an elec. or gas dryer...
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Mar 26, 2010 | Whirlpool Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
MY drier heating element shows 9 ohms continuity, it also shows 120 volts into and out of it when the drier is running. But the heating element wont heat up?
Have you checked the voltage at the outlet? You're supposed to read 220-240 VAC at the heating element. Your dryer heating circuits require at least 220 VAC to work. The motor, however, only uses 120 VAC. That's why your dryer may be running, but the heating circuits aren't heating. I would go back and check your outlet. You may be missing one leg of the 220 service, or have a loose, burned, or broken wire in the plug or terminal block (on the back of the dryer). Let me know what you find. I hope this helps you.
Oct 17, 2008 | Whirlpool Dryers
Whirlpool LER5636EZ3 dryer won't heat
hi If it reads 0 hms yes thats te problem Thanks the appliance doc
Sep 12, 2008 | Whirlpool LER8648P Electric Dryer
Leq9508 whirlpool dryer
The heating element should read 9 to 13 ohms. Double check again and make sure you disconnect the terminal wires before taking the reading to eliminate the possiblity of parallel resistance. If the readings are not within the tolerance listed, replace the heating element.
Jun 07, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
121 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
