Question about Stainless Garden Sun Steel Propane Patio Heater
The propane ignites, but shuts off after 2-3 minutes
I have pressed the pilot button for 2 minutes to clear the line, at least 10 times. Each time, the pilot lights, I turn the heater on to high and it burns fine for about 2-3 minutes. The it sort of "blows out" and the gas shuts off. There is absolutely no wind in the area. What do you think the problem is?
Thank you
Albert Bender
  • 116 Answers
Check to make sure the thermocouple is stays in the pilot flame could be bad i think lowes has them in the water heating section
Posted on May 11, 2009
Heater will not light
My blue flame heater's hose is over 12' long and when hooked up for the first time takes several minutes of pressing the pilot button for the air to clear and the propane to come through so it lights. Perhaps you are not waiting long enough for the gas to enter the unit?
Mar 25, 2013 | Mr. Heater MHVFB30LPBT BlueFlame Electric...
Have a Reznor propane heater, suspended, the pilot light ignites, though the ingniter runs continuously, thepilot light burns for about 2 minutes then everything shuts off, never ignites the main burn
First clean the flame sencor if fitted jump out the pressure switch see if thhelps , Also there are two snap discs high and low temp try jumping these out 1 at a time .
Mar 12, 2013 | Heating & Cooling
Pilot light went out
open the inspection door at the base of the unit ,usually at the front of the heater.There will be a round knob with On,pilot and off ,turn the knob to off. Go and have a cuppa. The air inside the gas line has to disapate.After 10 mins turn the knob to pilot, press down on the knob ,holding it down and at the same time press the ignition button several times and peer into the unit to see if there is a flame. If so continue to hold the knob down for one minute.Release the knob and turn to On. Your unit should start to heat straitaway. Good luck
Mar 12, 2013 | Water Heaters
The pilot lite in my sears 10 natural gas furnace model 867764510 will ignite but go out a short time later.
simply replace the the thermo couple. Any home depot. Very easy.Be sure all doors are in place or it could cause the flame to pull away from the thermocouple. If the problems new, change it. 5 minutes literally. Shut off gas and get the correct legth(18,24,36,12 inches.
Nov 05, 2012 | Heating & Cooling
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
Propane heater wont work
I'm not sure about that model, but I think you have to hold that button down for a minute or more to "prime" it.
I have a different model coleman propane heater that sits on the 20# tank. Mine is probably getting rusty, last time I used it I had to hold that button down for a long time.
I'm looking for a new heater now myself, as mine won't stay lit outdoors in much wind.
Dec 22, 2008 | Heating & Cooling
Pilot won't ignite
For SBP12,
It will take some time for the gas to get to the unit, just turn it on and wait. It might take 5 to 10 minutes to fill the line with gas.
Oct 20, 2007 | Procom ML300EBC Heater
Stainless Garden Sun  Steel Propane Patio Heater Logo
393 people viewed this question
Top Stainless Pool & Spa Experts
Merv Vickery
Merv Vickery
Gene Haynes
Will Townsen
Level 1 Expert
Are you a Stainless Pool and Spa Expert? Answer questions, earn points and help others
