Question about Mongoose Gravity Games BMX Bike
Back tire changing on mongoose gravity games bike. How do you change the back tire in this bike? It is very hard and confusing. I don't know how to do it. I need help.
    President:
  • 1,138 Answers
If you have pegs on the back you will need a deep socket to fit the nut and a socket extender and a socket wrench. with the wheel off it is just the same as changing any other bike tire. Just make sure you check the inside of the tire carefully for anything poking through that may puncture your new tube. Also check to see if you need a new tire and make sure you inflate the repaired tire to the correct pressure or you may get a pinch flat.
Posted on May 13, 2009
How to fix the back tire
Those are ball bearings. If they are out of the wheel you have a complex problem and repair. I suggest you take the wheel to your local bike shop.
Sep 14, 2014 | Mongoose 20-Inch Gravity Games BMX...
Who do I put the rear wheel back on my mongoose bike
raise the back of the bike and put the wheel between the rear stays place the chain on the freewheel, and pull the wheel back and
then just tighten the wheel nuts.
Jul 26, 2013 | Mongoose 20-Inch Gravity Games BMX...
Rear brakes tight, just repaired rear tire
Retrace your actions. It's something you did, right? LOOK. Is the wheel in straight?
Web search "install rear wheel"
Aug 13, 2011 | Mongoose 20-Inch Gravity Games BMX...
I can't get he front tire on my son's new Mongoose Showtime bike
Did you ever get it? Mine's messing up and now I don't know how to get it back on. If you figured it out, let me know.
Mar 14, 2011 | Mongoose 16" Boy's Kids Showtime Bicycle...
Cant put my mongoose bike together
If you bought the bike at a department store like canadian tire,you might be able to get them to put it together for a minimal fee.
Jun 21, 2010 | Mongoose Gravity Games BMX Bike
The handle bars turn separate from the tire, how do i tighten
Hi, get them straight, then tighten the one in the middle nearest to you on the stem, it's called when you are sat on the bike, also there could be a 2 bolts on the side of them stem... let me know...
mark
May 01, 2010 | Mongoose 20-Inch Gravity Games BMX...
How to replace a crank on a mongoose orbit 2008/9 series. My crank was bent from trying to do tricks so I need to fix my bike I never did this before so I need help
take the pedal off the opposite side that the chain is on the there should be two bolts turn the first one towards the back tire and take the washer out and use a flat head screwdriver to tae the second ne out the same way pull the first set of bearings out then pull it through the frame it might be a little hard but it will come out make sure you take the chain of the sprocket then put everything on the same way
Nov 24, 2009 | Mongoose 20-Inch Gravity Games BMX...
How to remove a sprocket from bmx back tire
Hello
Thank you for using
FixYa for your problem
There are 2 types of sprockets and both need the removal tool, take the wheel into a cycle shop and they should be able to do on the spot for you. If you are planning to change the sprocket often it could be worth getting one yourself, I have brought one - easier now
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
FMF Racing
Nov 18, 2009 | Mongoose 20-Inch Gravity Games BMX...
How do i remove the back sprocket from a bike with no gears?
This information provided by Park Tool's help page is all the info you need. It includes pictures and the necessary tools involved.
Hope it helps,
matt
Oct 13, 2009 | Mongoose Gravity Games BMX Bike
Remove back tire
Vise grips or a pipe wrench if theres not wrench spot at any place. Lefty loosey righty tighty 8)
Sep 22, 2009 | Mongoose 20-Inch Gravity Games BMX...
Mongoose Gravity Games BMX Bike  Logo
482 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
