Question about HP Photosmart 8250 InkJet Printer
Printer won't print
I'm getting the error message Oxc18a020a.
My printer has been in storage. I just replaced ink cartridges and had to unstick the carriage arm. Now it is giving the message listed above.
  • Anonymous May 13, 2009
    can you guide me how to change these ink waste tank filters?
  • Anonymous May 23, 2009
    error 0xc18a020a ink systemfailure
    Scholar:
  • 152 Answers
That error usually means you need to change out the Ink waste tank filters located at the base of the printer - this is best changed by an actual HP tech - they can be very temperamental to remove properly. The cartridges probably leaked during storage. Next time, pull all of the carts out of the printer prior to storage.
Good luck, please rate this answer if you found it helpful.
Posted on May 11, 2009
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Hp 8250 printer error Oxc18a020a
try to follow the next steps:
  1. Figure 1: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
Mar 23, 2013 | HP Photosmart 8250 InkJet Printer
Printer was inactive now won't print
The ink might be dryed up in the cartridge, might need a new one.
Dec 29, 2012 | HP PhotoSmart C4480 All-in-One Printer ...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Bypassing cartridge message s405
You won't be able to bypass the "missing cartridge" error. All cartridges needs sufficient ink left for the printer to print. If one the cartridges is out of ink it will damange the printhead.
May 12, 2012 | Lexmark Interpret S405 Wireless All-in-One...
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    Wont print with all new ink cartridges
    If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
    However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
    May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
    Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
    I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
    ben
    Nov 06, 2008 | Office Equipment & Supplies
    DELLA 940 DOES NOT PRINT
    Hi there Error 50c
    Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
    1) Press Power to turn the printer off.
    2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
    3) Turn the printer on.
    4) Remove the color ink cartridge.
    5) Lower the printer (scanner unit) until it is completely closed.
    If the error message displays again, replace the black cartridge with a new black cartridge.
    If the error message does not display, repeat steps 1–3 and then go to step 6.
    6) Reinstall the color cartridge and remove the black ink cartridge.
    7) Lower the printer (scanner unit) until it is completely closed.
    If the error message displays again, replace the color cartridge with a new
    color cartridge.
    If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
    8) Lower the printer (scanner unit) until it is completely closed.
    If you get the error message again, while both cartridges are installed, replace both of the cartridges.
    Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
    You may have to buy a new cartrige.
    Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
    All The Best: Pineworks
    Jul 20, 2008 | Dell A940 All-In-One InkJet Printer
    HP Photosmart 8250 InkJet Printer Logo
    438 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
