Question about Dewalt 3800 PSI Pressure Washer
Not getting pressure I was washing my car with warm water from my house. I shut off the pressure washer to soap up my car when I restarted it I got very little pressure.
2 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: john deere 3800psi pressure washer will not siphon
The only way the washer will draw soap into the line is with either the black tip installed or with no tip in wand at all.There is a ball and spring inside of the pipe that the siphon hose hooks to so when you use the washer with alot or even a little pressure the ball is forced up and blockes off the soap inlet port.So if you use it with no tip in the inlet port is open cause the ball isnt being forced up by back pressure.I hope this makes sense.
Posted on May 22, 2010
What kind of soap is used in a pressure washer
Any water soluble washing agent ... depending on what you are washing. Some are not good if you are washing siding and will get the windows wet.
Oct 10, 2014 | Simpson PS3200 Powershot 3200 Psi Direct...
Water will not stopcoming out
I get this question a lot. Washer is flooding the house, water everywhere, won't stop. The first thing I say is unplug the washer. If the water is still coming in,(which it will on a stuck valve) shut off the water faucets. If that is not possible shut the water meter off. If you can stop the washer with the timer then I would say instead of a bad valve you have a plugged water level pressure hose.
As you can see the rubber tube from the bottom of the tub allows air pressure to push against the switch till it shuts down the valve and starts the wash cycle. Remedy this problem: Simply remove the tube from the switch and blow it out. Use them lungs!. Get that sand and trash out of the sump. Reconnect the hose tightly and pump out any standing water. Then restart the machine. If you have a good tight connection the machine should start working like normal. No parts needed! LOL!
Jan 10, 2010 | Washing Machines
We have a Kenmore frontloader pooring water from soap dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 16, 2009 | Kenmore 44102 Front Load Washer
The washer keeps filling and won't stop. Sometimes can get it to stop on the wash cycle but won't stop filling at all on the rinse cycle. Any solutions?
I get this question a lot. Washer is flooding the house, water everywhere, won't stop. The first thing I say is unplug the washer. If the water is still coming in,(which it will on a stuck valve) shut off the water faucets. If that is not possible shut the water meter off. If you can stop the washer with the timer then I would say instead of a bad valve you have a plugged water level pressure hose. Look at this diagram: water%20level%20operation.jpg As you can see the rubber tube from the bottom of the tub allows air pressure to push against the switch till it shuts down the valve and starts the wash cycle. Remedy this problem: Simply remove the tube from the switch and blow it out. Use them lungs!. Get that sand and trash out of the sump. Reconnect the hose tightly and pump out any standing water. Then restart the machine. If you have a good tight connection the machine should start working like normal. No parts needed! LOL!
Sep 12, 2009 | Maytag Performa PAV2200
Water will not shut off to begin cycle
Does the washer leak water into the tub even when it is not on. If so, your fill valve is leaking or sticking.
I would also check the following components for problems:
-Air pressure switch. This is usually located inside the control area and likely is attached to the water level control. Try attaching a small piece of tubing to the pressure switch and gently blow into it. If it turns off, the problem likely lies elsewhere.
-Air tube. This clear tube can get crimped or worn from the vibration of the washer's normal operation. Any holes, cracks or crimps will prevent the air pressure created by the water in the tub from getting to the pressure switch.
-Soap residue in the air dome. The airdome is the piece attached to the side of the washtub that allows water in the tub to exert air pressure into the tube and the pressure switch. Soap residue can create an obstruction that prevents the pressure from being transmitted up the tube. Try cleaning with vinegar or ammonia. (Remember: Clean the tub and tubing thoroughly with water after cleaning. Ammonia and Vinegar are both corrosive to electrical parts.)
Hope this helps!
May 28, 2009 | Kenmore 23822 Top Load Washer
Wahing machine overflowing
Water does not enter the pressure hose, air does.
Remove the plastic tube from the air dome on the side of the washer. Use a small piece of wire and clean the soap scum out of the air dome hole. Blow through the plastic tube to hear the water level switch click.
Inspect the plastic tube for a hole or pinched.
If these steps do not work replace the water level switch.
Mar 24, 2009 | GE Washing Machines
Green whites?
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Soap Dispenser won't empty
Feb 25, 2009 | Kenmore Elite 45986 Front Load Washer
Small brown spots on whites
Nov 15, 2008 | Maytag PAV2300 Top Load Washer
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dewalt 3800 PSI Pressure Washer Logo
194 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
