Question about Garden
I have a Republic EZ drop fertilizer spreader. The gray plastic device (2 pieces, one screwed inside the other) up by the push handle that rotates to widen or narrow the slot at the bottom of the fertilizer storage bin when the handle is squeezed is broken. The cable connecting the device to the movable part of the slot is OK. The gray plastic has numbers on it that show through a small square opening in the gray plastic closest to the push handle. Where can I get a replacement part?
  • Anonymous May 12, 2009
    Does anyone know where I can get replacement parts for Republic EZ rotary spreader.
Posted on Jun 09, 2009
I have the same problem with my spreader. The gray plastic adjustment device has broken. How do I find a replacement?
Paul
p-bushouse at bethel dot edu
Posted on Oct 17, 2009
To correct this with out getting new parts you have to mark the manually gage the opening for each of the different types of fertilizer. The easy solution would be order the T-handle(w\Controler lever, Micrometer and wire). If yours is like mine it seams that I have wore out the controler lever and the wire will not adjust properly. I have adjustedthe black calibraion screw and know where it is supose to be for 4-1\2 whick is supose to be marked on the shutoff plate.
Posted on Aug 05, 2010
I need the plastic impeller that rotates the fertilizer for the rotary spreader.
You will need to know what make and model spreader you have as a starting point.
Oct 04, 2014 | Garden
I have scott drop spreader and I want how it will setting for fertilizer
Check the fertilizer bag for instructions. It will tell you the number to set it at for a drop spreader and a broadcast spreader.
Aug 14, 2011 | Scotts Company Garden
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 | Garden
The handle that should release the fertilizer, does not work.
With the bucket empty and the handle pulled open are ther holes in the botom of the bucketif not its jammed shut just needs cleaning with wd40
Jul 11, 2010 | Scotts Company Scotts 73730 AccuGreen 3000...
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Apr 29, 2010 | Scotts Company Scott'S& Lawn Pro Spreader...
How do I calibrate Scotts Accugreen 2000 for pounds of Fertilizer per Sqft. What do setting equal?
To adjust calibration, do the following:
1) Adjust the micrometer setting to 6.
2) Turn the spreader over.
3) Squeeze the trigger against the handle.
4) The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper.
5) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Note: If the hopper is missing a calibration line - with the setting at 6 they should be able to pass a 9/64" drill bit through the opening just to the right of center. (First opening to the right of the spring.)
Nov 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
Repair parts for a Republic EZ Broadcast Fertilizer Spreader
I have a problem with a broken handle it looks like there is no parts for the EZ Broadcast Spreader. The sad part is the rest of the unit is in great condition.
Looks like plan obsolescent!
Sep 06, 2009 | Garden
How do I calibrate my acugreen 1000 drop spreader?
The spreader comes already calibrated. The opening of the gate is determined by the setting that you input from the handle. This will correspond to the recommended settings provided on the fertilizer bag.
Best regards, --W/D--
Aug 09, 2009 | RTO Accugreen 1000 Drop Spreader
Garden Logo
3,864 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
