Question about Samsung RS2630SH Side by Side Refrigerator
Ice/frost accumulation around fan (behind panels in freeze)
This appears to be an epidemic problem judging from the comments on the web. I had the frig for 2 years before the fan started hitting the ice accumulation and making noise. Is there a permanent fix for this problem?
  • Anonymous Nov 05, 2007
    Yeah mine is freezing soda cans to the point they pop. I had set it at 46F the highest temp. still to no avail. I called samsung support and they immediately start accusing me of not putting things where they belong and overloading before I could tell them I do not stuff the fridge. I keep only 2 weeks of food in the fridge and empty every 2 weeks before shopping, leaving 1/3 empty. They refused to send a tech to repair it. I told them I will just buy a GE, Maytag or anything else, never to buy another samsung product.
You've probably found the answer long ago, but just in case - we had the same problem, Samsung have a replacement interior panel and fan assembly which addresses the problem. Our was replaced under warranty, and the problem has gone away. I think the new panel has some kind of heater strip to prevent ice accumulation.
Posted on Aug 11, 2009
  • 3 Answers
    P. S. >  As an afterthought - Check your Door Seals.
       Jerry
Posted on Oct 23, 2007
There are 2 fixes -ALWAYS PULL THE PLUG WHEN DOING ANY REFRIGERATOR CLEAN-UP . The light bulb can melt the plastic of your refrigerator if left on for more than 5 minutes.
#1,PULL THE PLUG FROM THE WALL and leave the doors standing open, let the refrigerator defrost then wipe all the mositure out. This should take all morning. Be careful to put towels or whatever rags around the refrigerator as the ice melting in the refrigerator will probably overflow the drip pan and flood your floor. I take mine out on the porch. After the refrigerator is cleaned of ice and whatever spillage, plug it back in and run normally. If this happens again take the defrost timer to an appliance shop and ask them to test it. If you have a repair manual for your refrigerator follow the dircetions on testing the defrost timer. Usualy a refrigerator freezes-up due to an above average amount of moisture. This can be caused by open bottles of anything which includes water,soda,beer,warm food from the market or from the table or just leaving the door open to long or opening and closing to many times, this happens in most households with teenagers who open the door every 20 minutes or so. If the problem continues and you are sure is is not the above, it is probably #2, There are heaters in most refrigerators, some are metal like the bake element in and electric range or some are glass and have broken by the pressure of the ice. I caution you that  to check this yourself might be dangerous and troublesome as you have to remove the back panels inside the freezer compartment. (above all when doing anything like this, MAKE SURE YOU HAVE PULLED THE PLUG)!!!. You can only check them with an Ohm-meter. I would suggest you call an appliance repair shop to check this out as there are usually 3 heaters in the freezer compartment, if one of them is broken or burnt out then the othe 2 elements will not work. Some models do not have heaters but reversable compressors. Check your Repair Manual for this to be sure.
Ice cube maker and fan has stopped working in the freezer section,and ice has started to appear half wY up the freezer section,can anyone help?
Ice accumulation may or may not be related to the failure of ice maker and fan. If the fan has simply failed, then frost will build up as a result of cold air not being circulated in the freezer. If there is no evidence of physical impedance such as accumulated ice blocking operation of the fan; remove the fan, check function outside the unit and replace the fan if it does not work when you apply AC. Avoid electrical shock!
The major cause for ice appearing in freezer: When the defrost cycle begins, the freezer elements are heated to melt accumulated frost. If the melt water is blocked from draining, ice will build up from repeated freezing and melting, thereby decreasing functionality to the point of complete failure. You must find the blockage and remove it.
Blockage is from food particles which have entered the drainage tube and failed to pass to the evaporating pan located in the area of the compressor which from the heat of the compressor allows drainage water to evaporate. The principle is simple and direct, but accessing the components to remove the blockage without permanently damaging the fridge can be frustrating, and will be messy dealing with accumulated ice while the contents of the freezer you placed on your kitchen table are defrosting. Removing ice is best accomplished by melting it with a good hair dryer. Big towels, water collecting pans, patience and extreme persistence are also required. You will be amazed at the amount of ice you will be dealing with. Unplug the fridge and do not chip at the ice.
If your unit is still under warranty, do not hesitate to call for repairs. When the service person attends the problem, watch carefully, note the sequence of operations, closely observe his or her technique, because this will happen again. Clearing this ice can cost you $300 or more each visit.
Some designs have called for a restricting nipple located at the end of the tube supplying the evaporation pan. This serves to impede the tiniest of debris inside the tube, progressively freezing the blocked water up to and beyond the drain located under the freezing fins then into the freezing compartment itself. Remove that nipple! Your repairman will not remove it because it voids the warranty if you still have one. The nipple is there to assure the industry you will be buying another $2000 unit soon.
My first fridge lasted 37 years before I decided to purchase a new one due to increasing inefficiency. I unblocked its drain tube twice in those 37 years. There were no restricting devices. The particles were simply inevitable chunks which got caught over time and unlike modern units, were easy to access. That unit was a large GE frost-less, We were careful through the years to keep dust from the condenser coils..... so we thought. When I got the unit into the yard, I tipped it forward to discover dust impacted around the 18 inch condenser coil stack inaccessible when the fridge was in the kitchen. A high pressure water source was required to blast away that densely compacted dust. After the unit dried, I plugged it in and the efficiency was as good as new, but I already had a new unit filled with food, standing in the kitchen where the old GE once stood. Despite that, the new fridge uses only an average of 30 watts continuous power, cutting my electric bill in half, paying for itself in saved power consumption over three years.
Regarding the new unit, I had to clear the melt tube twice. First time under warranty, second and last time after I fixed it. My brother bought the very same unit, having refused the expensive extended warranty, called me about two years after purchasing it mentioning ice accumulation in his freezer. I told him what to do over the phone. He bought me some beer.
Jan 20, 2016 | Refrigerators
TFX22JR. Why did The freezer stop freezing (contents are liquid)?
It appears that you have a malfunction of the defrost system;
locate the defrost time and turn clockwise until you hear a click; at that point, you manually advanced the time into defrost. if after a few minutes you hear water coming into the drain pan (under the fridge), it means that your defrost heater and thermostat are OK and you just need a defrost timer. if it does not start to defrost, you better call a tech as you may have different problem that you probably cannot resolve without the right tools and training.
If you order the timer, you must still defrost the freezer through 2-3 additional defrost cycles to remove the frost that accumulated over the past week. make sure that no frost remains behind the panel before turning back on
good luck
Aug 02, 2015 | GE Refrigerators
Top drawer of freezer seems to work but large bottom drawer not freezing even at -5degrees. Can this be fixed?
This problem seems to be two sided. A refrigerator defrost it is supposed to take the water from defrost down a pipe located behind the freezer rear wall to a pan below the refrigerator where there is a fan blowing warm air over the water to evaporate back into your home or business. If that drain is blocked your refrigerator will accumulate a large block of ice and frost behind the rear panel of freezer and temperatures will warm considerably in fresh food compartment and freezer. Here is one site I want you to read over=> Leaking Refrigerators Just What may Be Happening and here=> Leaking Refrigerators here is a link to a service manual=> LFX25960xx Service Manual Let me know if this service manual is close enough to your model number. At this point I am looking for air blockage behind the rear panel of freezer. If air is being blocked by ice and frost you can use a hair drier to help speed you up while melting ice. If drain is blocked use whatever you can to open the drain line mentions on the links I sent you to and let me know what is found, Thanks Sea Breeze
Feb 18, 2012 | LG LFX25971ST Bottom Freezer French Door...
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
We get no water or ice from control panel. On panel it says Er iF. What does that mean and how can we fix it. We have tried resetting the power and it goes back for a second then returns to Er iF.
Er IF - Ice-maker Fan Error - This can be caused by frost accumulation on or around the ice maker fan. Unplug the unit for 3-4hoursto allow this to melt off. If error code persists, call customer care to check & replace ice maker fan motor.Thanks.
Jan 29, 2011 | LG LFX21960 Stainless Steel Bottom Freezer...
Freezer fan is making noise so I took all food out used a hair dryier to try and melt some of the frost/ice behind the back panel. Before this all the food had frost on them. This is the second time I did...
you need to have someone check the defrost circuit. if the unit does not defrost properly , ice will accumulate on the back panel where the evaporator is, blocking the evaporator fans completely, and the circulation fan will eventually stop working because the ice buildup contacts the blades all the fan motor, and eventually the refrigerator compartment will start to get warmer and warmer because there is no circulation of cool air.
Mar 16, 2010 | LG LFX25960ST Stainless Steel French Door...
Frost buildup at back of bottom freezer department. Refrigerator should be frost free. Freezing impaired.
could be anumber of things happing, is the freezer fan spinning? if not ice will accumulate( also hamper cooling in the refrig section). perhaps a defrost issue, a bad heater or defrost thermostat could also cause, this/ may even just be the door being left open for extendedperiods of time( ie.. overnight, or hte gasket not sealing correctly) leading to a frost build up on rear panel
Jan 27, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The freezer (top) is freezing cold, bottom is not cold
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor (which senses temp and ice build up) that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. If this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that may have occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of it being due to overfilling are slim...I have been in the industry for 35 years and that is what freezers do...which a lot of people don't realize is that freezers don't actually cool anything ..they just remove heat and when you remove all the heat all that is left is cold (like in space) and when heat is removed quickly frost can appear like when you blow your breath on a freezing cold window..then right your name....but I digress...any way..if there was an excess of heat due to a lot of new food in the freezer it would correct itself by one of the processes i mentioned above..and it would never result in Ice..you probably have one or more of the problems I mentioned...evaluate how long its been going on...
4. Thermostat could be out of adjustment..and or not functioning
properly..which would delay or inhibit a defrost cycle..from occurring..unfortunately almost all of these problems require a tech...or a good handyman.
5. Another problem is the condenser fan motor may be out...it is under the refrigerator...and can be accessed from behind the refrigerator......be careful as you pull the frig out as water lines are attached...(generally)...if motor is fine..check to make sure there is not a lot of dust and or dirt accumulation around the condenser coils...if there is clean them with a shop-vac ....dirty condenser coils can cause ice build up also...since the condenser removes the heat evacuated from the freezer.
6. And the final problem is ..it could be a restriction in the evaporator line...(though this is rare)...if you pull the cover off of the back of the freezer and find ice in an isolated area of the evaporator...it could be a restriction...it will most likely have ice all over the evaporator.
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..thanks for rating my effort.....The Fang
Apr 22, 2009 | Whirlpool Refrigerators
Ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Nov 28, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frost accumulation on ice maker
Normally the frost is taken away during defrost so if things get worse we need to look at the defrost timer.If freeze temps.begin to rise let me know, Thanks JT
Oct 24, 2007 | Frigidaire FRS26KF5C Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
518 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
