Question about Health & Beauty
Norelco 7865XL battery replacement
Can someone provide me with instructions for removing and replacing the batteries in the 7865XL?  Once open it is not obvious how to do this without possible damage to the shaver.
  • 1 more comment
  • Scissorhands Dec 30, 2007
    Razor wont work after recharge-wondering if battery is dead-took it apart-and it seems soldered in. If I do replace the battery-how do I solder it-and is that really why the shaver does not work anymore?
  • paulkner Jun 08, 2008
    trying to replace batteries in norelco 4805XL
  • ALFAQ Oct 12, 2008
    HOW DO I GET TO THE BATTERY PACK
Norelco 7865XL will not hold its charge any longer. I can leave it in the charging station & I can get a shave out of it, but I can't leave it out very long. How do I get into change the battery if this is the problem? Is it something I can do? Where can I purchase a battery?
Posted on Dec 12, 2009
I just replaced the battery in my 5842XL. The batteries have tabs that are soldered on a circuit board. If you are careful, you can pry the tabs off of the batteries. I used a small screwdriver and needle nose pliers. The tabs can be flattened. The new battery pack made good electrical contact with the original tabs. I recommend taping the new batteries together to make them easier to handle prior to installation. Good luck.
Posted on May 04, 2008
I just took apart my 4805XL. Used a solding iron to heat up the battery tabs and pulled the battery pack off. Replacement found online for $13.95 plus shipping.
Posted on Jul 16, 2008
HQ8 or HQ6? What is the correct head replacement?
These Philips Norelco Replacement Shaving Heads HQ8/52 are compatible with the following series: 7100 series, 7200 series, 7300 series, 7700 series, 7800 series, 8800 series, PT/AT700 series and PT/AT800 series. They are sturdy and durable and provide for a smooth finish. The Norelco razor heads keep your shaves close and comfortable and are easy to replace.
Norelco HQ6The Norelco HQ6 is men's replacement heads. The Norelco HQ6 is made up of stainless steel and contains 3 cutters. The Norelco HQ6 works with all Quadra Action razors. HQ6 Features:Replacement Heads Stainless Steel 3 Cutters / Combs
Norelco HQ6
Oct 14, 2015 | Head Health & Beauty
The battery dies with three green lites still showing. How do I reset the battery memory to get a full charge, and the flashing red lite when low ?
This problem indicates that the battery is worn out and needs to be replaced. You will find the correct battery type for model 7864XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. There are two metal clips that must be unhooked for better access. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Dec 29, 2010 | Norelco Quadra 7865 XL Electric Shaver
How do I replace the batteries in my Norelco 7865xl shaver? I see how to remove them, however, they seem to be hard fixed in the shaver. I do not see how to disconnect them from the shaver then how to...
You will find the correct battery type for model 7865XL at shaveroutlet.com. See link below.
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Dec 05, 2010 | Norelco Quadra 7865 XL Electric Shaver
How do I replace the batteries on my Norelco Spectra 8845XL shaver? I read somewhere that they need to be soldered on. That's not a problem, just want to make sure I do it correctly. Also, where can I...
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Nov 30, 2010 | Norelco Spectra 8845 XL Electric Shaver
Cool Skin 7775X My razor only works when it is immediately taken off the charger. Once it is shut down it needs to be put on the charger again. Is this the battery and if so can it be replaced?
It sounds like the battery pack needs changed. You will find the correct battery type for model 7865XL at shaveroutlet.com. See link below.
To replace, you will need to remove the back cover by removing the screws on the back. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Nov 30, 2010 | Norelco Cool Skin 7775X Electric Shaver
I have a Norelco 8865xl. It needs new batteries. How do I replace them?
Nov 29, 2010 | Norelco Health & Beauty
How to install a replacement battery
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Nov 23, 2010 | Norelco Quadra 7865 XL Electric Shaver
How are the batteries replaced on my norelco 7865xl
You will find replacement batteries for model 7865XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To open shaver, remove the two screws on the back. Lift off back cover. Then remove the two metal clips inside to get access to the battery pack. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Aug 17, 2010 | Remington HC-600 Hair Trimmer
Health & Beauty Logo
3,205 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
