Question about Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
Troy Bilt power washer 020293- Oil in air filter
Troy Bilt power washer model 020293 Brigg & Stratton engine- Using it for 2nd time this spring and oil starts to drip from air filter box. I opened the cover and filter is now 50% saturated. (The power washer continued to function without any loss of power.) Obviously I shut it down as soon as I noticed the problem. What gasket should I suspect has blown or is there any other immediate suspects? Unit is ~2 years old and may have (at most) 50 hours of use.
That is incorrect. if the oil has been over filled, it will saturate the filter element by way of the crankcase breather tube. it is the small plastic pipe that connects to the bottom of the filter housing. check the oil level. these machines take very little oil. approx 20 oz. if overfilled, it will leak out filter.
Posted on Apr 28, 2010
The filter is saturated with fuel not oil it looks close but not oil it is a function of the carb it sprays fuel to prime the cylinder it has ust over sprayed into the filter no gasket needed
Posted on May 28, 2009
Lawn Mower putt putt when filter in place
Your air filter screw may be too long from over tightening air cleaner and crushing the cover. It warpes the carb allowing for gas to leak into carb. Grind or cut off screw alittle or put washer on and don't over tighten. thank you for using fixya.
Jun 12, 2013 | Briggs & Stratton Garden
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
I have a Troy Bilt 2550 psi Power Washer with a Briggs and Stratton 675 Series, 190cc engine. Could you tell me what kind of oil I should use.
Best oil for small engine for most moderate climates is 30wt non-detergent. The pump can use mineral oil (air compressor oil ) sold at most auto stores and lumber outlets.
Jul 02, 2011 | Garden
Briggs & Stratton 650 (Model 120000) lawnmower engine on a Troy-Bilt CSV060 lawn vacuum/chipper/shredder. Was stored for several months with no oil/gas. Recently got it out and filled oil/gas. Would...
you are clearly burning oil. did you overfill? or tilt the unit so that engine oil went into the carb through the breather? now the carb may be soiled/partly clogged, you need to clean it. esp. the idler air part may be at fault. sometimes it is possible to run it at high rev until the fuel has washed out the oil, but better clean the carb and replace the air filter.
Jul 08, 2017 | Troy-Bilt Heavy Machinery
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
Oct 07, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Troy bilt pressure washer
You need to replace parts 37 thru 41 on the pump breakdown.
Click this link for the breakdown.
Mar 17, 2009 | Garden
Turn Black cone shaped valve clockwise to increase pressure there will be a small +/- plus will increase and give you pressure.
TK U
Mar 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Briggs & Stratton Pressure Washer Projectpro Spray Nozzle  Logo
2,045 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
