Need access code for magnavox smart series 20 mt-1331-17
I need to get an access code for my magnavox Smart series 20 mt-1331-17. It was already set and i dont know what it is.
No video no sound has raster
Posted on Jan 15, 2011
I forgot the code for my philips magnavox tv smart series, how do i unlock it? model #13MT1431/17
0279,0285,0291. Try these codes. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 10, 2014 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
Is there an 800 number I can call o get the factory setting for the smart series Philips magnavox tv? It was manufactured in August of 2003.
Try this number- the unit may have a defect in it and may need repair- you don't say what is wrong with it.
http://www.support.magnavox.com/html/index_us_en.html
Aug 09, 2012 | Philips Remanufactured Magnavox...
How to disable TV-G
Press the Menu button on your remote.Scroll through the menu to the smart lock feature. The access code will be 0711 unless it has been changed. If this is not the correct code or you lost the code just unplug the unit for about 30 seconds. The 0711 code will then work. You can then chose to turn the Master Block off or change your blocked rating settings.
Aug 16, 2010 | Philips Magnavox 20MT133S 20" TV
HOW TO REMOVE CLOSE CAPTION FROM SMART SERIES TV
on your remote go to cc push that until it sayes closed caption off not positive but pretty sure
Jan 11, 2009 | Philips Magnavox 20MS233S 20" TV
Need Unlock channels
I called Philips Magnavox at 1 888 744 5477 and they told me the default ACCESS CODE number is 0711. It works on my TV though it didn't solve MY problem of the TV defaulting to Chanel 9 every time I turn it on. Drats. Hope this helps.
Jan 01, 2009 | Philips TP2784C TV
Need codes to unlock the smart block on my phillips magnavox tv
do you have a 3 digit code for RCA TV for the philips universal remote?
Dec 30, 2008 | Televison & Video
Smart lock
If that function was put in use by the previous owner, the fastest way to change the parental lock out would be to contact your friend and get the access code from them.
Since the set probably uses a bit of flash memory to store the access code and other settings, if an individual chip, that would have to be physically removed and replaced.
If you can locate service information on your set, it will likely contain a procedure to set the memory back to factory default.
Jul 06, 2008 | Philips Magnavox 20MT133S 20" TV
Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
Sep 07, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Televison & Video Logo
308 people viewed this question
Top Televison & Video Experts
