Question about Vehicle Parts & Accessories
I locked my keys in the trunk and when the tow truck driver opened the car door, it activated the security alarm. The trunk release under the arm rest doesn't work. Any suggestions as to how I can get the trunk open.
    President:
  • Vehicle Part... Master
  • 2,923 Answers
It would help if you listed what kind of car you have. SOME cars you can get into the trunk by taking the back seat out and with long extensions, remove the latch.
Posted on May 11, 2009
Car has been towed now alarm keep going off
You need to get it fixed. When it was towed they probably hit on something.
Mar 24, 2015 | 2005 Ford Ikon 1.6i
Keys locked in trunk of 2007 bmw z4
Accually the car itself is easy to open but the trunk is a different story. If the car was unlocked by someone and it set off the alarm it will dissable the release On a lot of late models they have what they call easyout door locks. When the door is open look in the door jam beside the lock and look for a plastic or rubber cover over a hole. Remove this cover and then remove the screw behind it but becareful not to drop inside the door. After removeing the screw you can manipulate the lock out of the door from the outside. Then take a flat blade screw driver and lock and then unlock the door. This in most cases will reset the security system and then the trunk release will work.
Mar 04, 2012 | BMW Cars & Trucks
How do i manually release the rear door on a ssab 9-3 2003 as the door module has failed
Trunk Lock After Closing
Desc.: What happens to the trunk lock when closing it.
Settings:
Yes: Automatically lock Boot on closing
No: Boot can be reopened using micro switch button located on the trunk/boot
* Trunk Lock After Drive Off
Desc.: Should the trunk be locked at drive off or after 30 sec.?
Settings:
Yes: Trunk/Boot will automatically lock when vehicle increases speed
No: Trunk/Boot will remain closed, however will be in the unlocked
condition if No was selected in the previous option.
* Door & Trunk Unlock at Key Out
Desc.: When the is removed from the center console should door/trunk
be unlocked?
Settings:
Yes: All Doors & Trunk/Boot will Unlock when the Key is removed from
the Ignition Switch If Driver frequently locked all Doors when
driving
this feature would be beneficial.
No: Doors and Boot will remain in the same condition as they were
prior
to Key removal
* TSL Locking Logic (Theft Security Locking/Deadlock)
Settings:
TSL at first Press: Default Setting. All Doors will lock in Deadlock
Mode
TSL at Second Press: All Doors will lock in Deadlock mode at the second
press of the Remote.
* Lock /Unlock Acknowledge
Settings:
None : No acknowledge will be visible
Indicators: Indicators will blink as acknowledge
* Follow Me Home Function
Settings:
Tail Light: When selected Tail Lights will be illuminated
Back Up Light: When Selected Reverse Light will be activated
Tech 2 Body Exterior Lighting & Horn
* High Beam Follow me home Active Time
Desc.: Follow Me Home Active Time can be adjusted between 0- 10 minutes
Settings:
This Feature can be turned on or Off .Yes / No can be selected.
Low Beam Automatic / Low Beam also in Position 0 (light switch)
Yes / No
- Daytime Driving Lights can be activated
* Parking Lights
Settings:
Act as Lead Me To the Car Light.
* Park Light On Reminder
Settings:
On / Off
If Ignition is turned Off and the parking lights are active, Driver will
be warned if set to on.
* Show Trailer Light Outage
Desc.: REC will detect blown trailer light and display on SID
Settings:
Yes or No
* Trailer Light / Fog Light off
Settings:
Yes: Fog Light Rear will be disabled When Trailer is connected Yes
No
* Horn Lock Unlock Acknowledge
Settings:
On: Horn will honk when car is locked
Off: Horn will not honk if car is locked
Tech 2 Body Locking
* Panic Alarm Activation (Vehicles fitted with /Alarm only)
- Panic Button / Locking Switch
Central Locking Switch Driver /Passenger
Settings:
- Panic Button on Remote and locking switch inside vehicle will
activate alarm
- Panic Button will activate Alarm only
- Locking Switch inside vehicle (driver /passenger will activate
alarm only
- No Panic Alarm function required.
* Unlock Logic
Settings:
All at first press : All Doors will open & Fuel Lid will unlock if the
Driver or Passenger Door Switch is activated
Driver Door & Fuel Lid at first press : Only the drivers Door will unlock
& Fuel Lid will unlock when door
switch is activated
* Remote unlocking One Press
Settings:
All at first press: All Doors will open & Fuel Lid will unlock if the
Remote is pressed
Driver door & Fuel Lid at first press: Only the drivers Door will unlock &
Fuel Lid will unlock when the Remote
is pressed
Dec 17, 2010 | 2003 Saab 9-3
I have a 1997 infiniti I30, one day all of a sudden when I came out of a grocery store I turned the key and absoloutely nothing happened. My lights can come on inside the car but, my power windows wont...
This is from Ken on CarPros:
Here is the way to reset the security system.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Here is the systems descriptions
There are 2 security system, namely anti-theft and immobilizer.
Here are the 2 systems.
DESCRIPTION & OPERATION
Anti-theft system is controlled by Body Control Module (BCM). BCM receives signals from hood switch, trunk switch, door switches and Local Control Modules (LCMs). There are 5 LCMs located throughout vehicle.
To set anti-theft system in armed mode, remove ignition key, close all doors, trunk and hood. Lock doors using key or remote controller. The SECURITY light will illuminate for 30 seconds, then flash in 2.4 second intervals, indicating system is in armed mode.
To cancel armed mode, unlock and open any door or trunk lid using key or remote controller. SECURITY light will flash every second, indicating system is disarmed.
Alarm will activate (horn sounds, headlights flash and starter circuit is disabled) if any of the following conditions occur while system is in armed mode:
Engine hood or trunk lid is opened using the hood or trunk lid release.
Door(s) is unlocked without key or remote controller.
Tampering with any door/trunk lid key cylinders.
To deactivate anti-theft system, unlock door or trunk using key or remote controller.
If it is the immobilizer that is preventing the engine from being started, ensure you have the correct key and the transponder is intact. Quite often keys are dropped and if it breaks open, the internals would scatter all over. When this occurs, there is a tendency for the transponder to be lost.
Please let us know happens so it will help others.
Best, Ken
I hope that helps you out!
Mar 31, 2017 | 1997 Infiniti.5 J30
1999 porsche 996 replaced key fob battery disconnected battery now trunk releses are locked and cant access battery.How do you open frt trunk manually
Assuming the car battery is ok (if not, buy a male to male cigarette lighter at the auto store and connect to another car until charged enough to unlock the doors...but don't try to crank the ignition!). The trunks won't open if the battery went dead with the alarm set because arming the alarm physically locks the releases.
Sounds like the key code is switched off because you replaced the key fob battery. Try unlocking the car manual with the key in the door lock. Then switch the ignition on to reactive the keyless entry. If this does not work, you might also try pressing the fob unlock button with the key in the door lock until the dash led flashes.
Jun 10, 2010 | 1999 Porsche 911 Carrera
How do i reset my alarm on a 97 jeep Grand
Here is excerpt from the 1998 Jeep Grand Cherokee Service Manual ... i know you posted under 1997 JGC but this information may be helpful ... by "reset alarm" i believe you meant disarming the alarm?
Arming
Passive arming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is exited with the key removed from the ignition switch, the headlamps are turned off, and the doors are locked using power lock switch. The power lock switch will not function if the key is in the ignition switch or the headlamps are on with the driver’s door open. The VTSS will not arm if either front door or the liftgate are locked using the key in the lock cylinder.
Active arming of the VTSS occurs when the Remote Keyless Entry (RKE) transmitter is used to lock the vehicle, even if the doors and/or the liftgate are open when the RKE transmitter Lock button is depressed. However, the VTSS arming will not be complete until all the doors and the liftgate are closed.
Following successful passive or active VTSS arming, the VTSS set lamp on the top of the instrument panel will flash rapidly for about 15 seconds after the illuminated entry system times out. This indicates that the VTSS arming is in progress. If the light stays on steadily during the arming, it indicates that the hood switch is closed (the hood is open). The VTSS will still arm if the hood is open, but the engine compartment will not be protected. Once the 15 second arming function is complete, the set lamp will flash at a slower rate to indicate that the VTSS is armed. Disarming Passive disarming of the Vehicle Theft Security Sytem (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter. Once the alarm has been activated (horn sounding, exterior lights flashing, and the the engine no-run feature), either disarming method will also deactivate the alarm. Depressing the Panic button on the RKE transmitter will also disarm the VTSS, but the horm will sound and teh exterior lamps will flash for about three minutes as a part of the Panic feature function. ..." And as an additional note, if you have the courtesy interior lights set at 30 seconds like i do, you have to wait until lights go out (with alarm still sounding) before you can disarm the alarm via passive disarm method... what a pain when you don't have the actual RKE handy... Good Luck!
Feb 14, 2010 | 1997 Jeep Grand Cherokee
Keys lock in trunk alarm will not allow trunk switch to lock
The solution is to pull out the back seat to get into the trunk. There are two bolts holding the bottom part of back seat (bolts located between bottom and top sections). Then pull out bottom section of back seat and you see the hinge for the top section, remove the bolts and then you can lift up and access the trunk. It's not that hard.
Jun 08, 2009 | 2008 Hyundai Elantra
How to reset 1995 nissan sentra security system
larrylisa2: When you refer to reset, do you mean arm the system?
If so, it can be done providing all the doors, the trunk and hood are closed.
Using your key, you can lock the drivers door or passenger's door and it will arm the system. The trunk, all the doors and hood must be closed.
You can also arm the system without the key in the same fashion insuring all the doors, trunk and hood are closed.
To disarm the unit, you can do this from the driver's door, front passenger's door or the trunk lock.
The other option is the remote. There is one other way to shut down the alarm system. Disconnect the negative battery cable, put the ignition key in the run position and reconnect the cable. This will keep the system from arming until the car is locked.
There is no reset procedure other than the ones I have described.
Apr 25, 2009 | 1995 Nissan Sentra
Vehicle Parts & Accessories Logo
48 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
