Question about GE WDSR2080D Top Load Washer
Long to fill tub after washing cycle
After washing it takes awhile to fill up with water, to spin and rinse.
    Genius:
  • 1,198 Answers
The cold water control valve may be clogged. Take the hose off and check it's flow, and check for a screen at the connection. For a quick test, reverse the hoses and see what happens.
Posted on May 11, 2009
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
this could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Dec 08, 2014 | Samsung Washing Machines
Washer tub does not move to spin or wash
You either have a bad solenoid, timer, loose belt, or water level sensor.
Dec 15, 2013 | Haier HLP21E Top Load Washer
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Water not filling in tub washer spins,
It sounds as if the timer has failed internally. Spinning on each setting means the motor is not reversing and that reverse function is controlled by the timer itself. It would never fill if it is stuck in spin unless you select rinse and depending on cycle it can inject water in the spin during the final rinse. If your machine does this normally see if it injects water. If it does inject water at that point I am 95 % sure your timer is the problem.
Jan 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Dec 30, 2008 | Maytag SAV3655A Top Load Washer
GE WDSR2080D Top Load Washer Logo
27 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
