Voltage of LaCie power supply
Ineed toreplace the power supply for a La Cie "Neil Poulton" 500 G disc drive. What voltage doesit need? Thanks Graham
  • 490 Answers
If you remove the old one it should be labelled on the side of what its voltage is and just get the same as that one
Posted on May 27, 2009
My computer is not recognizing my hard drive.
You will need data recovery help. This guy does it remotely and works off of donations. FreeDataRecovery.us
Jul 12, 2011 | LaCie Hard Disk design by Neil Poulton...
I have a lacie 500gig external hard disc and i fail the optimization and the disc shows only 9.9mb and i formatted in hope that will have the same setup assistant -but i turn wrong.Please tell me a...
click start control panel administrive tools computer management scroll to disk drives if you can see your drive right click select properties tools tools you should see click check now click start tick in two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box then wait for that to finish
also + to expand right click you should see options update driver disable uninstall scan for hardware changes
hope this helps
May 06, 2011 | LaCie Hard Disk design by Neil Poulton...
I need to install lacie stup assistant.or download
LaCie Setup assistant is made to make it easier for the customer.
If you do not have it, you can format your drive using your MAC or PC and you can download manual and utilities from the LaCie website, which are the only things the assistant really does.
Regards,
Jan 10, 2011 | LaCie Hard Disk design by Neil Poulton...
My external La Cie 500Gig HDD has worked well for 3 years or more. Now when I connect it (via USB as aI have always done) ..The following happens: 1 I see the drive usually but not always under "My...
your drive has failed at either the power supply level or internal hard drive level.
First, please verify your power supply. When plugged into the power outlet, it should be silent. A defective power supply will hiss or have a high pitch noise to it. If it is defective, replace it and check if the issue is resolved.
If the power supply is silent, one or both of the internal hard drive is failing. If no data is needed, you can either replace the defective one which you will have to isolate by connecting the internal hard drives to a computer or with another enclosure and running a block scan software like hdTune which is free to download. The other option would be to scavenge the healthy drive and use it in another enclosure or inside the computer directly.
If you need the data and the problem was not the power supply, you will need to contact a data recovery center.
Regards,
Jan 07, 2011 | LaCie Big Disk 500 GB Hard Drive
Hi. I have a LaCie Hard Drive designed by Poulton with N2870 on it. I've misplaced the external power cord adaptor, and need to know what kind to get. The guys at Radio Shack said they need to know: ...
I have the same one. The power supply I have says input 100-240V output is 24W 12V 2A.
I'm replacing the power supply but my big problem is not knowing the polarity of the tip There is no sticker on the hard drive itself or on the power supply (that I suspect is fried). Can anyone help?
Lisa
Dec 13, 2010 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
I have an old La Cie 160gb (maybe 5 years old?) - do you know the specs? rpm, for instance? I need something with 7200. This old one must be 5400, right?
Lacie drives have a 5400 RPM on there 160GB line nothing really changed until 500 GB to 1tB at 7200 RPM.
so the answer is 5400 RPM
Hope this helps please do rate and leave feedback.
Apr 29, 2010 | LaCie (300740) 160 GB Hard Drive
Lacie 250 GB (Neil Poulton) external hard drive not recognised on PS3 (20 GB) . My friend has a Maxtor 250 GB drive, he can play just about anything from his drive on the PS3, but i cannot. The drive does...
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
Blu light flashing
This is most probably a faulty power cable, a common fault on La Cie apparently. Another cable got my disk working fine!
Nov 12, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
