Question about Canon DC10 DVD Camcorder
Disc error HEllo I have a Canon DC10 DVD Camcorder Problem i keep on getting a disk error\no disk im useing a sony handycan dvd-rw and I tried Verbatim dvd-rw not sure what to do
  • 1 more comment
  • senorahicks Jan 03, 2008
    I had the same problem using Maxell dvd's - it happened to me twice and would not allow me to finalize the dvd. I sent the camera to Canon under warranty (if you have had it 1 year or less) and they "fixed" the problem and sent it back. It did the same error again the first time I used it after it was "fixed". I returned the camera to the store where I bought it and now I cannot find that particular model anywhere.
  • Antimatter1 Jan 26, 2008
    i bought a DC-10 with a problem that the disk motor does not spin up. The screen indicates it is trying to access the disk but after it times out it says no disk. I determined this by opening the drive door inserting a blank dvd and actuating the door latch mechanism thus fooling it in to believing the door was closed. No spin-up. Everything else works great. I have to test the SD card function still. The next step is to purchase a repair manual from canon. I will post any further results here...
  • Anonymous Aug 01, 2008
    I HAVE A CANON DVD DC10 CAMCORDER. I KEEP GETTING DICS ERROR AND I CAN'T GET PAST THIS. ANY SUGGESTIONS?
I think motor is broken, if you want i have one. amaizing1985@yahoo.co.uk
Posted on Jul 03, 2008
SOURCE:
Will dvd+r discs work at all in a canon dc10 camcorder-I have 2 I just got and they show disc error when trying to initialize-thanks
From the camera's user manual on page 6, it says that it can only use DVD-R and DVD-RW disks, so no.. No it can't use DVD+R (or DVD+RW) disks.
Dec 21, 2010 | Canon DC10 DVD Camcorder
Format error when i finalise the disk
If a FORMAT ERROR message is displayed, then the inserted disc is not formatted or it is recorded in a different format not useable by the camcorder. If using a DVD-RW or DVD+RW, format the disc prior to use. Otherwise, use a different disc.
Mar 21, 2010 | Sony Handycam DCR-DVD201 DVD Camcorder
When I put a disc into the camcorder it reads "disc error"
My DC10 Camcorder is now coming up with error message 'replace battery pack'. Have done this and not solved problem, will not turn on at all?
Mar 17, 2009 | Canon DC10 DVD Camcorder
Problem formatting mini dvd+rw disc
The full user manual is available at:
http://pdf.crse.com/manuals/2587623111.pdf
If the procedure fails, the disk may be corrupt but you might try formatting the disk on your pc.
Hope this helps. Please rate reply if it does thanks.
Feb 24, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
Problems with my Canon DVD model DC 210
make sure that "plus rw" is allowed to be used (dvd+rw). My DC330 requires "minus rw" (dvd-rw).
(You'd think the gurus would differentiate their specs better, no?)
Also, I just learned today that the charger needs to be plugged into to be able to finalize a disk. Found the answer in a review on Amazon, rather than in the manual. That's an hour of my life I'd like to get back.
Nov 25, 2008 | Canon DC210 DVD Camcorder
I have problem importing videos to my computer using (Roxio MyDVD for Canon)
be sure that you installed the cd driver camed with your camcorder and also try using ULEAD MOVIE MAKER as im using now with my camcorder. its very easy to use. hope that helps!
CHARCOIS
Sep 24, 2008 | Canon DC10 DVD Camcorder
Cannot eject finalized disc
Try turnin the camera to the side where gravity will help pop open the disc and be careful not be keeping it close with your own hand. Its a thin cover and you can accidently be holding it close without knowing.
May 24, 2008 | Canon DC10 DVD Camcorder
Initializing DVD-RW Discs
This camcorder only takes DVD-R and DVD-RW, it will not work with the +R discs. I've used Maxell and Fujifilm discs and they both worked fine. You have to make sure the camcorder is plugged in the wall when initializing or else it won't initialize.
May 22, 2008 | Canon DC100 DVD Camcorder
Camcorder won't format my DVD-RW disc
try a different brand of dvd recordable disks? maybe? that would be my suggestion before anything else...hope it helps.
Sincerely,
Rabeka Jo
May 15, 2008 | Video Cameras
Canon DC50 will not accept canon dvd-rw disc
Had the same problem went to the Disk Menu and Inialized the disk, Problem solved.
May 07, 2008 | Canon DC50 DVD Camcorder
Canon DC10 DVD Camcorder Logo
467 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
