Question about Freeplay Energy Summit AM/FM/SW Radio
Summit freeplay "locked"
My radio has got "lock" on the top of the screen. It still displays the time and when winding it still brings the green led up ok
  • mikethebike Oct 12, 2007
    After posting the problem and used the summit web page and pdf manual. this states to change the battery, remove the two black bands and remove the five screws. split the radio carefully and the circuitry is on one half and the battery and generator on the other. My battery voltage was 3.8v which seemed OK. then just disconnected the battery power socket for approx 15seconds until the screeen goes blank. then reconnect reassemble and reprogramme.
If you push the time set and alarm set buttons simultaneously this will lock/unlock the radio
Posted on Aug 26, 2008
If you push time set and alarm set buttons simultaneously you can lock/unlock the radio
What would be the probable cause of a sony vaio fs830/w of starting up & the 3 green leds on top stayed lit
You were FORMATTING it? Meaning... you were erasing the operating system? If that's the case, then... you have no operating system and the computer cannot boot up because it has no operating system to boot into.
Jul 30, 2014 | Sony VAIO VGN-FS830/W Notebook
My Freeplay Summit radio keeps switching itself off and the volume is really low. I've had it over five years, but am gutted it's on it's way out. If it's too expensive to fix, then for...
fraid to tell ya it's had it's day and is stuffed, and it's not worth fixin and is worth nuthin. Drop it in the bin an git yerself down to radioshack or Walmart for a new one.
Feb 04, 2018 | Freeplay Energy Summit AM/FM/SW Radio
It says 'lock' on the screen and does not operate at all. How do you unlock?
hi,
This can happen if the Hold or Lock switch is in ON position. Watch is there is any Hold or Lock switch at any side of of your radio. If found then just slide it to off position. If the Hold or Lock button is in ON position it will deactivate all the other switches.
ok
Jun 16, 2011 | Freeplay Energy AD022 FM Radio
Dishwasher won't start, turns on but no display
1: Defective door lock switch
2: Defective electronic control board.
Get model and serial number of machine, enter model number on search engine and seek same like conditions. You should find solution to problem, or place model number here for me to correctly tell what is wrong.
Oct 01, 2009 | Dishwashers
I have an original freeplay clockwork radio which has died. Help!
Hi , you have probably expired the battery life out of the radio [ they have a recharge battery life ] but all you have to do is replace those recharge batteries with new recharge batteries and your as good as new
Jun 12, 2009 | Freeplay Energy BayGen AM/FM/SW Radio
When I plug the 12v/240v adaptor in the radio turns off
The polarity of the adaptor was reversed, not a 12v one as I posted but the normal 6v! , changed it back and all now ok.
Apr 10, 2009 | Freeplay Energy Summit AM/FM/SW Radio
Blue LED display too bright
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
Nov 02, 2008 | Boston Acoustics Recepter Clock Radio
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Locked radio?
I h ad the same problem which I took of the two black plastic caps removed the five screws which splits the radio in two pieces. Just follow the leads from the battery and disconnect the plug on the board until you lose the display then put every thing back together and reproggram it again.
Mike
Sep 21, 2006 | Freeplay Energy Summit AM/FM/SW Radio
Freeplay Energy Summit AM/FM/SW Radio Logo
445 people viewed this question
Top Freeplay Energy Audio Players & Recorders Experts
RudeRude
John In Milford
John In Milford
Are you a Freeplay Energy Audio Player and Recorder Expert? Answer questions, earn points and help others
