Question about KitchenAid KFP740 Food Processor
I have the unit plugged in and the ingredients in the bowl, but it will not pulse...what am i doing wrong?
  • 145 Answers
I am assuming that the unit is not getting any power whatsoever and this is not isolated solely to the pulse function not working.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Posted on Jul 07, 2009
Cuisinart DLC-10S food processor leaks when liquid is above blades
Yes. It's the basic physics of all liquids.
Perhaps a blender might be a more suitable tool?
Generally you would use the food processor for mixing/blending/chopping all the dry ingredients (and maybe the butter if you are making something like cookies).
Separately mix all the really wet ingredients together in a mixing bowl/large measuring cup.
Then combine the dry ingredients from the food processor with the wet ingredients in a mixing bowl (you can fold the dry into the wet if you used a bowl to mix the wet ingredients together. If you used a measuring cup for the wet, then it's usually better to put the dry ingredients into the mixing bowl first, making a depressed area in the center, and then add the wet into the dry.)
Nov 28, 2013 | Cuisinart DLC-10S Pro Classic Food...
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Light comes on but won't pulse or turn "on."
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Aug 03, 2009 | KitchenAid Food Processors
Unit assembled, lights are on (pulse, on) nothing happens
Jul 19, 2009 | KitchenAid KFP740 Food Processor
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
May 09, 2009 | KitchenAid Food Processors
Can't figure out how to turn on Regal LaMachine I food processor
It's very easy--but you have to know the trick--I know 'cause it took me awhile to figure it out. Place the machine with the on-off/pulse button on your left. Lock the container in place--the handle will be on your right. Put the blade on the shaft. This is the trick: Lock the lid in place so that the shoot is directly in front of you and the "***" slides into the **** on the left of the machine (between the container and the inside of the machine, left of the on-off button). Good luck!
Nov 25, 2008 | Regal Ware K813BK La Machine Food...
Food processor
I phoned the 800 number at Cuisinart (800-243-8540) and the person who answered the phone explained to me what to do: Fill the bowl with the hottest tap water I have (but not boiling) above the entire blade (including the part that fits over the shaft). He said to pulse a few times, then try to pull it off, but not to expect it to work right away. He said to do this until it comes off and that it could take 1/2 hour. I did what he said, and the blade came off after the first pulses. But also, the water was pouring out all over the counter--leaking between the bowl and the base (possibly because my old work bowl is also cracked, but I'm not sure).
I was told that the problem would happen again, and that I needed replace the blade and the shaft (which is cracked, as he guessed), both of which are available from Cuisinart.
Oct 07, 2008 | Cuisinart DLC-5 Food Processor
Kitchen aid model kfp 7 The wide slicer disk cut into the top of the cover leaving pieces of plastic in the sliced potatoes. What would cause this to happen.
This may be caused by a number of factors. Most commonly, it is because the work bowl is being over-filled or too much pressure is being exerted on ingredients as they fall through the feed tube. Doing this may cause the disc to come off balance and start sheering plastic.
Call Kitchenaid Customer Service and provide them with this description. They will replace the unit free of charge, regardless of it's age or warranty. Their toll-free telephone number is:
1.800.541.6390.
Aug 25, 2008 | KitchenAid KFP740 Food Processor
I have a kitchenaid kfpw760 food processor. I assembled it as per manual then added ingredients to work bowl, but...my ingredients are below the blade in the bowl and the blade doesn't contact the...
The work bowl lid has a feed tube on it, and the unit should have also come with a "feed tube pusher," a plastic piece to help depress food through the feed tube itself.
With a food processor, you will want to assemble the unit first, engage, and then add ingredients. This will ensure the ingredients fall through the blade and/or disc to be processed thoroughly.
May 11, 2008 | KitchenAid Professional KFP770 Food...
KitchenAid KFP740 Food Processor Logo
674 people viewed this question
Top KitchenAid Food Processors Experts
xalint1
xalint1
Shehu Pro
Shehu Pro
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
