Question about Whirlpool 18.2 cu. ft. Top Freezer Refrigerator ET18PKXG
The refrigerator is collecting water under the veggie drawers. The model is ET18UMXGN0 2.
  • 1 more comment
  • mrgferguson May 10, 2009
    Thanks for answering!
    We did the defrosting but it keeps happening. Is there something else we can do before getting a new fridge :)
  • Sue Irwin
    Sue Irwin Apr 28, 2017
    Water collecting under bottom veg crispers. CTX,21DABRRWW
  • Sue Irwin
    No drain in fridge
    Visited the website for 30 consecutive days.
  • 560 Answers
Even thought it is frost free. Defrost it (turn off) for an -hour and plug in.
Also a good idea to vac out motor compartment and coils in back.
Try the EZ stuff 1st.
Hope this helps Mike
Posted on Apr 28, 2017
  • 62 Answers
The fridgerator needs to be defrosted, take everything out of the freezer and refridgerator and unplug it for about 8 hours to allow all the ice to turn into water and then clean out all the water and clean the fridge and make sure it is all dry, now turn it back on and it should be good to go.
Posted on May 10, 2009
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
Where is water comming from found in bottom under veggie drawers
often a blocked drain. The drain pipe should empty on to a collection bowl on top of the compressor. If you can blow sharply up this pipe, the blockage should clear.
Apr 29, 2012 | Samsung RS2630SH Side by Side Refrigerator
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
Water collects under veggie drawers constantly and leaks out when opened
You probably have a clogged drain in the freezer. The easiest fix would be to remove all food and let the unit thaw for 24 hrs with the doors open.
The other option would be removing the freezer panel and taking a turkey baster with hot water and running it down the drain line until it thaws.
Jan 22, 2010 | Refrigerators
Kitchenaid refrigerator mdl KTRS22M has water under veggie drawer
Hi, water could be excessive moisture, check door gasket, or check drain at back above veggie drawers, could be block, make sure produce not blocking drain hole, clean, check carefully for drain.
Aug 02, 2009 | Refrigerators
Water collecting under veggie drawers on bottom
check to see if defrost hose is clogged under veggie drawers
Aug 02, 2009 | Kenmore Refrigerators
Why is water forming under the veggie drawers
One of two things caused this problem, either the drain in the freezer is clogged and spilling over to the air duct and through to the refrigerator, down the back wall and then puddling up under the drawers or the Styrofoam between the freezer and refrigerator is saturated with water. If you remove the inner back wall of the freezer and there is ice built up, defrost it with hot water and a turkey baster, push some heavy weed trimmer line down the drain tube and they should clear the clog. If there is no ice build up, then you probably have the latter of the two problems, the only solution is to empty the unit, turn it off, and let it dry out for a few days with the doors opened. If the problem continues, then there is a significant breakdown of the Styrofoam between the two cavities and there isn't a solution, it is time to purchase a new unit.
Jun 16, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Mar 21, 2008 | Refrigerators
Refrigerators Logo
175 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
