Question about Kenmore Washing Machines
Drum seems to be off its bearings
The drum seems to be off its bearings. When it is tuened by hand it can seem ok for a moment then seems to slip off the larrge dai thrust /rotary bearing that the clothes get loaded thru on a fron load washer. Can the preload on that bearing be reset?
Kenmore front load clothes washer, model # 417.43142260
    Genius:
  • 1,198 Answers
Http://www.pcappliancerepair.com/whirlpool-dryer.php#books This site has parts, manuals, and the pictures you see when you put in your model number will give you a quick peek into the unit.
Posted on May 11, 2009
The dryer drum is not spinning it seems to be stuck, can someone help me get the drum attached properly and working again.
What does it do when running? Is the belt just slipping around the drum?
http://rduappliance.com/washing-machine-and-dryer-repair/
Jan 02, 2015 | Dryers
Maytag washer pav5157aww
Your pump is probably stiff. Bearing is going out.If the pump is ok I would look at possibly replacing the thrust bearing. Their could be something between tubs.
May 15, 2013 | Maytag Neptune Washer
Amana nav5805aww washing machine won't spin
You will need to replace the thrust bearing kit. Here is the part to order.
It comes with the instructions and is an easy fix.
Oct 30, 2012 | Amana NAV5805A Top Load Washer
Keeps tripping out my down stairs sockets.checked the wires going to the machine and the plug.all seem fine.? Please help
IS BEARINGS OK IN DRUM IF NOT THE DRUM HAS GONE THROUGH HEATING ELEMENT ...TURN DRUM BY HAND IT SHOULD BE SMOOTH .. OTHERWISE CHANGE HEATING ELEMENT.
Feb 27, 2011 | Indesit W 123 Front Load Washer
Hotpoint ultime wt640 has a slight squeek seem to be on front around door area had top off and turned drum motor and drum seem fine and springs ok
Remove rear cover of washer, remove drum belt,and from front of washer, spin drum by hand.
There should be no noticeable noise.
If you can still hear sqeek, then it could be a drum bearing that is dry or starting to fail. or the drum is rubbing on the front of the door seal
You should be able to detect what it is this way.
Please rate my solution.
Thankyou.
Jan 17, 2010 | Hotpoint Aquarius WD640 Front Load...
Front loader noisey
Hi.
If you remove the belt and turn drum by hand, it should revolve freely and without any noise.
If it is noisy or feels stiff, then you proabably have main drum bearing failure.
Could be expensive to put right
Nov 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Maytag MAV6000 Top Load Washing Machine
Tip the machine back remove the belt try to turn the drive pulley manually . sorry the larger pulley in the centre. if you can turn it counter clockwise and feel the inner drum moving then the thrust bearing is ok. if not you may need to replace it.Also a bad lid switch can cause this problem.
Nov 07, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
122 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
