Question about Black & Decker BL1900R Blender
Blender stops working
This is my replacement blender and once again it has stopped working.  I push any button and the light comes on but there is no power.  I turned it off for hours and tried again, still not working.  I've checked the power.  I've made sure the top is on correctly and blade spins.
  • 11 more comments
  • Anonymous Dec 31, 2007
    I have exactly the same problem
  • vujn Mar 18, 2008
    Have bought two Black & Decker blenders model BL1900R at Target and neither work right out of the box. I followed instructions, unplugged units and still nothing. I will never buy Black & Decker again!!!
  • allibarbara May 02, 2008
    how do u ask for replacements if its 4 months old
  • Lisa04 Jun 02, 2008
    You know. I only got to use it once and it went dead on me. Except for a blinking light on it. I have checked circuitbreaker and let it sit for a few days and it is still not working. Please help me.
  • kumlina Jun 09, 2008
    Hope Black and Decker has a quick solution once business hours resume. Ridiculous. 3-4 times I used it and now it has stopped with a solid blue light. Anyone ever get any other tips on how to resolve this?
  • Anonymous Jun 09, 2008
    This was a wedding gift. I may have used it twice? Same problem...machine stopped working and only a blue light comes on.
  • Anonymous Jul 13, 2008
    blue light on but blender isn't working
  • Anonymous Jul 29, 2008
    blue light comes on but doesn't work.
  • csimon Aug 19, 2008
    Same problem
  • ED 1934 Dec 16, 2008
    Yep, I have the same problem with my BL 1900 R (red) and I have a stainless steel one that looks the same so I want to switch housing but there is one screw that looks like a slotted head but the slot doesn't go clear through, like this _ _.
    Ed
  • Anonymous Dec 18, 2008
    Blue lights come on but no movement.
  • Anonymous Jan 22, 2009
    I have the exact same problem after using it 5-6 times. And I was just starting to get good at making smoothies, dammit!
  • Anonymous Apr 09, 2009
    same problem - have used about 5 times and now only the blue light comes on.......i am thinking about returning it to Target.
I also have the same problem...it is brand new...worked 3-4 times and stopped. Spent $65 for a nice blender. I will also NEVER buy black and decker again.
Dallas, TX
Posted on Mar 20, 2008
Two buttons are stuck in on my kitchen aid blender.
I have been searching for an answer to this same problem. My chop and mix buttons were stuck and I was getting no power or blinking lights. After finding no help on-line, I decided to take it apart and fix myself. It was easy and it worked!
1. Take the bottom of the mixer off by removing the rubber foot pads and remove the exposed 4 screws.
2. Remove the 3 sets of wires that are attached to the inside panel with clips. Very easy to remove, just squeeze at the base of the clips and pull up.
3. Remove the 2 screws holding that panel in place and gently lift off.
4. Remove the panel found under the top panel by also removing 2 screws. When you flip this panel over you will see what operates the switches.
In my blender the black plastic nubs that push against the buttons that were stuck and got twisted off kilter so they were not resetting properly. I just put a small screwdriver in there to try and straighten them as much as possible. All of these steps will be obvious as you disassemble the blender.
5. Push on the back of the buttons that were stuck to get them unstuck before reassembling everything back together.
I was surprised how easy a fix this was and how obvious what the problem was when I opened the blender up. No soldering or fancy tools needed, just 5-10 minutes and a phillips head screwdriver!
May 21, 2013 | KitchenAid KSB560 5 Speed Blender
After blending cake batter the blender became hot and it's not working what shall I do
You have burnt up the machine. It will no longer function and would be unsafe to try further. Replace it.
Jun 03, 2017 | Philips HR1350 SingleSpeed Handheld...
I was using my blender and stopped to add more ice for a smoothy mix, but when I tried to start it up again the lights began flashing at random but the blender would not work. Why?
It sounds like it may have overheated. Firstly, Switch it off and let it cool down for a few hours. Quite often it will burst back into life. If not, you will probably need a new control board. These come in several variations:
9708845 Silver 110v 9709339 Black 110v W10291857 Silver 240v
Mar 25, 2011 | KitchenAid KSB560 5 Speed Blender
WHEN i PUSH ANY BUTTON TO TURN IT ON, IT WORKS FOR A FEW SECONDS THEN IT STOPS, i HAVE TO UNPLUG IT AND SHAKE IT, IT WORKS FOR ANOTHER FEW SECONDS THEN IT STOPS AGAIN. wHAT CAN i DO TO FIX IT?
Sounds like the brushes are not making good contact or you have a defective switch. Run the blender witout the container or blades . Free run it for 5 minutes id you can and see if that helps.
Oct 20, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Kitchenaid Blender Classic
Same thing happened to me. Opened it up and along the red wire to the motor is a bass fuse. Went to the hardware store and then I replaced it. Works fine.
Apr 12, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Apr 16, 2008 | Breville CBL10 BlendMaster Classic Work...
5 speed ...steel
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask, strawsj1234@hotmail.com
Sep 11, 2007 | Black & Decker BL5000 ProBlend Work Top...
Stopped working
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask.
Sep 01, 2007 | Black & Decker BL5000 ProBlend Work Top...
Black & Decker BL1900R Blender Logo
2,045 people viewed this question
Top Black & Decker Blenders Experts
Marvin
Marvin
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
