SOURCE: Default username for 5461 maxg
Hello, The easiest way to correct it to reset router back to default. Reset hole/button on back need to be held in 10-15 seconds. 5 seconds or less and it will reboot router. Once it is reset to default use 192.168.1.1 for address and "admin" for password. Leave usename blank. After in settings these can be changed. Hope this helps.
The default username is admin.
The default password is admin.
that's the default passwords. it does depend on the type of reset whether you will still have the old passwords or not. be that as it may i'm also including the user manual for you
http://www.cisco.com/en/US/docs/routers/srp520_series/srp521w/administration/srp500_admin.pdf
i do hope this solution helps you
thanks
robert
