Question about 2wire 1800HG Router (RG1800HG00)
Connecting laptop to 2 wire
Ok...I have no idea what I am doing. I have a 2 Wire 1800HG Gateway router (or whatever it is called) this is hooked up to my desktop.....I have a Dell Latitude laptop that I would like to connect wirelessly to this router...how do I do that? I am completely stupid on this, so go slow. Do I need other equipment or do I need to just install something on the laptop in order to connect to the 2 wire?
  • Michael Galve
    Michael Galve May 11, 2010
    Are you using Windows XP or Vista on your new laptop?
  • 4,338 Answers
Here is a link with downloads for the User guide and Wireless Configuration guide for your 2-wire:
http://www.dsldepot.com/dslmodem.asp?modem=238
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 10, 2009
Having problems connecting my lap top to my wireless cable modem. Its a motorola SBG900 gateway. everything seems to be connected. Im able to use it with a ethernet cable just need help geting it to be...
Ok. As per your statement your laptop is working perfectly , when you are connected your laptop with with the cable wire.So the network cable is OK. So you have to configured the wireless cable in your laptop when it is connected to your laptop. After connecting the cable wire to your laptop you have to findout the gate way of your ISP ( Internet Service Provider). To find out the gate way , kindly follow the following instructions.
First findout the IP address , subnet mask,and Gateway addresses of your ISP ( InternetService Provider ).To find out the above mentionedaddresses first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses. Kindly note the Gate way address of your ISP. Then enter the gateway address in the browser and open the window. Then a control panel / a window will appear. It will prompt you to enter 1). user name, and 2) password. If you are having the user name and passwords provided by your ISP , kindly enter them in the window and click to open. Then the particulars of Motorola SURFboard SBG900 Wireless Router will be displayed in the window. Then click the wireless icon and click to enable. Hurray ! your laptop will work perfectly through wireless. If you are not aware of about the 1). User name and 2). password , you must approached to your ISP and try obtain the same for working of your laptop wirelessly.
Oct 03, 2010 | Arris SURFboard SBG900 Wireless Router...
Unable to have internet connection with my desktop that is connected to HomePortal (1800HG) by USB but my laptop can connect to internet that is attached to Local Ethernet Connection port; the three green...
Oh my ... This is a question where I dont have to ask for more information.
Pleae connect your desktop to the router using a Cat 5 ethernet cable. I'm not a fan of USB connection for networks ... Ethernet works so much better. Do this even if you have to add a NIC to your computer.
You may find some benefit from using Network Magic, free to download and evaluate. You may like it as much as I do and pay for full extended use NM can perform all your network administrator duties. (I have 5 interconnected networks in my house that connect more than 20 computers)
Thanks for using FixYa.com
Positive comments always welcome
a
Oct 28, 2009 | 2wire HomePortal 1800HG Router...
Ipod touch connection using 2 wire 1800HG
Check your router or the modem's settings. I had the same problem but when I tweaked with the modem, it worked.
May 06, 2009 | 2wire 2700HG-B Router (2700HGB)
not sure if the 1800hg is the issue log into the router and turn off the encryption temporarily then try to connect the ipod. if the router connects double check your encryption key. if not or it connects for a second and then drops may be the internal security for the router stopping the connection you may have to call 2wire to help you turn off some of the security to keep the ipod connected.
Apr 08, 2009 | 2wire 1800HG Router (RG1800HG00)
What is a 2 wire gate router
2 WIRE is a company that makes routers, Telus uses them to hook up television and internet.They don't appear to be any different unless you consider the fact that the ADSL modem and the router are combined into a single unit. All routers have a gateway IP, but its likely that a "gateway router" by definition may be just a router/modem combo, just a guess.
Jan 04, 2009 | 2wire (1000-400108-001) Router
1800 hg 2 wire wireless
1.can i use my 2wire 1800hg with vista?hooked up to ethernet connection.- yes its possible make sure you enable dhcp on your lan side of you router and under tcp/ip on your pc set it to authomatic assign IP address and dns server address. most router use 192.168.1.1 as thier default address to access it.
to fix your passkey problem.need to access the router and try to change the passkey then save and don't forget to restart the router after you save it,by unplugging it. "make sure your passkey is 8 characters long"
Nov 11, 2008 | 2wire 1800HG Router (RG1800HG00)
Can a 1800HG gateway in my garage/workshop link *wirelessly* to my 2wire 2700 HG-B wifi AP internet in the house?
try going onto http://192.168.1.254/xslt?PAGE=J30&THISPAGE=J29&NEXTPAGE=J30 on the computer connected to the 1800hg and set the router onto bridge mode (deselect enable routing). You might be able to set the two routers to connect then from here: http://192.168.1.254/xslt?PAGE=J09&THISPAGE=J30&NEXTPAGE=J09 or somewhere else in the MDC, not sure if it will work as I haven't tried it, but I hope it helps.
Feb 19, 2008 | 2wire 1800HG Router (RG1800HG00)
2 wire
if you are going to configure the router you can do it manually just lunch your web browser and put the I.P. address of your router on the address bar
Feb 13, 2008 | 2wire 1800HG Router (RG1800HG00)
Cannot open web page
If you can check you have DHCP and NAT enabled on you router and your laptop is configured for DHCP .Also try the following:
1.On command prompt type ipconfig /all
2.Check the IP address assign to your laptop do the same on your Pc and compare the IP.
3. If the IP is the same check your firewall setting. Assuming the IP is the same ping the Gateway IP .If this is successful the disable the firewall,The best way to try this is to disable the firewall temporary.
4.Remember to reenable the Firewall
Dec 01, 2007 | 2wire 1800HG Router (RG1800HG00)
Setting up the wriless network
You need to have a cable going from the modem to the gateway, and then another wire going from the gateway to the computer.
Oct 04, 2007 | 2wire HomePortal 1800HG Router...
2wire 1800HG Router (RG1800HG00) Logo
191 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
