Magnavox MP3 player wont work and will not fix
When I turn on the player it flashes Magnavox for a few seconds and then turns off. I changed the battery and it still does this. I downloaded the firmware and upgrade from the website but when I plug the player into the USB on my computer the screen just says OK to disconnect and will not go away. When I disconnect it from the computer it keeps saying ''OK ot disconnect'' until I remove the battery.
  • Anonymous May 19, 2009
    When I turn on the player it flashes Magnavox for a few seconds and then turns off. I changed the battery and it still does this. I downloaded the firmware and upgrade from the website but when I plug the player into the USB on my computerthe screen just says OK to disconnect and will not go away. When Idisconnect it from the computer it keeps saying ''OK ot disconnect''until I remove the battery.
  • schultz458 May 26, 2009
    No matter how charged up the batteries are, whenever I turn on my MP3 player, the word MAGNAVOX pops up for 3 seconds before the player turns off. Whenever I plug it into the player, it says ok to disconnect and never goes away,,,,the whole screen just freezes up
SOURCE: s1 mp3 player
first u have to download driver of that device then it will be detected and u have to extract firmware from same device of ur friends with same capacity and upgrade that file in ur player
Posted on Oct 26, 2007
SOURCE: Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site (http://www.everythingusb.com/forums/showthread.php?threadid=11238). To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
Posted on Nov 17, 2008
SOURCE: mp3 philips sa2325/55 doesn't work
Hola Amigo! Yo también soy de Argentina. Te cuento que yo tuve el mismo problema y no encontré la solución en la Red, pero no me quedé conforme y empecé a probar y por fin LO ARREGLE! No sé específicamente que fue lo que hizo esto pero te cuento que es lo que hice y creo que es la solución, ok?
1ero. hice una copia de todos mis archivos en el disco duro e hice un formateo al mp3.
Después entré en la página oficial de Philips que es la siguiente:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=JP&slg=ESP&cat=MP3_PLAYERS_CA&sct=FLASH_AUDIO_PLAYERS_SU&grp=PORTABLE_ENTERTAINMENT_GR&session=20080716011205_66.249.71.8&ctn=SA2325/55&mid=Link_Software&hlt=Link_Software
Si te cuesta escribirla poné en google:
p4c philips gogear sa2325 y ahí te va a aparecer.
Bajé el archivo que dice:
Actualización del firmware - Software, Version: 4.16 Inglés
Solicitud (1.34 MB), 2007-10-24
Y lo ejecuté a ese archivo. Aparentemente este archivo no hizo nada, no instaló nada, en definitiva pareciera que no hizo nada. Ahora abrí el Programa que me venía con el Mp3 que es el PHILIPS DEVICE MANAGER y ya el problema que decía BUFFER OVERRUN no apareció.
Pero acá no se acabó todo, porque la versión que yo tenía del PHILIPS DEVICE MANAGER era la 1.1.6 y solo tenía una opción que decía ACTUALIZAR, y cuando yo ponía ahí me decía que la versión de mi Firmware no necesitaba actualización.
Entonces lo que hice es bajar el siguiente archivo que está en la misma página que te dije arriba de philips:
Software: Device Manager, Version: V.1.4.6 Inglés
Solicitud (7.39 MB), 2007-10-25
Lo traté de actualizar al programa PHILIPS DEVICE MANAGER pero todo quedaba igual, así que desinstalé la versión vieja e instalé la versión que bajé, es decir la V.1.4.6
Después abrí el programa PHILIPS DEVICE MANAGER y para sorpresa mía tenía una opción a la derecha del botón ACTUALIZAR que decía REPARAR, hice click ahí, y cuando terminó el proceso mi MP3 había vuelto a la vida. Ahora lo estoy disfrutando!!
Espero amigo que te sirva y si puedes, le traduzcas al Inglés porque mi Inglés es muy limitado. Suerte. CAETO - TUCUMAN - ARGENTINA
Posted on Nov 23, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Computer does not recognize model sa5285/37 philips mp3 player
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
SOURCE: RCA Opal M4202 won't turn on
go on to www.rca.com and download the firmware
Posted on Apr 05, 2009
My ipod has this x thats in a circle and i t wont turn on
i desprately need you expertise to fix this problem
Dec 31, 2009 | Apple iPod classic MP3 Player
Screen froze wont turn off fully charged turned on played for a few seconds went to change song and whole thing froze up...
I suggest you hold the power off button. I've never used that MP3 player but I imagine you would need to resort to your manual. The manual should solve your problem, if not I would suggest taking it back or contacting customer support for help.
Thanks,
Brandon
Dec 09, 2009 | Philips GOGEAR SA6045 MP3 Player
Display on mp3 player shows "Magnavox" and then shuts off
MP3 players are so cheap nowadays, so Id recommend getting a new one instead.
Aug 09, 2009 | Toshiba gigabeat MES60VK Digital Media...
MP3 Player Abruptly Shuts Off When Turned On
mine was doing the exact same thing and when I took it to get fixed they said it would be cheaper to buy a new one
Aug 05, 2009 | Audio Players & Recorders
My rca pearl 1611 mp3 player
This probably wont be a big help but try changing the battery
Dec 24, 2008 | RCA TH1611 MP3 Player
Magnavox MSA2025 Problem
HI FRIENDS THIS IS KIRAN
TO SOLVE THE ABOVE ISSUE
* REMOVE BATTERY
*PLACE THE LOCK BUTTON IN UNLOCK POSITION
*INSTALL MAGNAVOX SOFTWARE IN THE PC
*CONNECT TO THE INTERNET
*CONNECT THE DEVICE TO PC HOLDING THE SYNC BUTTON ON THE DEVICE
THEN YOU WILL SEE AN MSG STATING "DO YOU WANT TO REPAIR THE DEVICE"
CLICK YES
Dec 02, 2008 | Toshiba gigabeat MES60VK Digital Media...
Magnavox mp3 player unable to charge via usb
Go to magnavox.com/usasupport and download the firmware and driver upgrades. Then do a launch device manager from your programs. Make sure and hold the return button on the top of the player until the magnavox device manager recognizes the player. The repair program will fix it. We just had the same problem and we fixed it. At first all it would say was magnavox and then turn off. It resets the mp3 player. You will have to reload your songs. Y
Oct 11, 2008 | Audio Players & Recorders
How to reset the mp3 player when it freezes::::
omg! it does work when u hold it fur 15 secs. about! i hav a ativa mp3 and i only had it fur like 2 weeks but it works!!! thnx alot!
Dec 20, 2007 | Audio Players & Recorders
Wont turn on
I had the same problem. Reset the device, by pushing the reset button down (a small hole next to the usb connector). Then hold down the play button for a few seconds. That should work. If that doesn't work, after reseting, hold down the play button and A-B Button for a few seconds.
Sep 28, 2007 | Samsung Yepp YP-T7JZ MP3 Player
My Mp3
In order to stop the player I hold the Stop button for a few seconds. Hope it'll work for U 2.
Mar 20, 2007 | Packard Bell AudioBell (64 MB) MP3 Player
430 people viewed this question
 Grubhead
Grubhead
