After washing clothes are still soapy
Soap on clothes after washing
    Genius:
  • 1,198 Answers
The washer may be using hot for wash, cold for rinse. If the cold water side of the water control valve has failed, you won't get rinse water. For a quick test, reverse the hoses.
Posted on May 11, 2009
5 Suggested Answers
  • 1028 Answers
SOURCE: suds residue left on clothes just washed
ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
Posted on Nov 27, 2008
  • 28 Answers
SOURCE: washing machine leaves clothes wet and soapy
most lightly the draining system is not working or not working effective enough,take the drain hose out at back lower till it is below bottom of the drum ,if water freely runs out ,there's a possible restriction in the pump impellor or pump has failed,if water doesnt flow freely out at a low level there is a blockage in pipe work
Posted on May 07, 2009
  • 6 Answers
SOURCE: Machine won't rinse or spin properly..also stinks!
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on May 08, 2009
TheMobilian
  • 8220 Answers
SOURCE: Soapy smell in clothes
You might need to wash your washing machine.
Most consumers think they are doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LG's part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective if used the proper way:
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Got that? LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 16, 2010
I have a older top loader model. My clothing has white soappowder marks on after a wash, especially my dark clothing. What can the cause be.
Possible causes:
1. Too much soap.
2. Water not hot enough to dissolve soap.
3. Not rinsing well enough.
4. Wrong type of soap.
Suggestion: try liquid soap.
Jun 11, 2018 | Washing Machines
I have a Semi Automatic Whirlpool Sparkle washing machine my question is can i put water in the dryer just to remove soap from the clothes
Whether your dryer is electric or gas, DON'T PUT WATER IN THE DRYER!!! If you need to get more soap out of the laundry, run it through another cycle without soap.
Jul 27, 2014 | Whirlpool Washing Machines
Washer can't remove the soap , and have to wash the clothes handly to clean soap
Remove the soap build up between the wash tub and the outer basin with a fridge or dryer lint brush. The soap accumulates and builds up between the two tubs. Clean it after a recent load of laundry so it has a chance to soften up. Make sure the washer is unplugged when you clean this area.
Use Borax and half the amount of soap in future wash loads to prevent this build up.
Mar 23, 2014 | LG Washing Machines
Dark clothes have lint left on them. what could help this problem?
Are you sure it is lint and not soap? My washer does this, and it looks like lint, but it is soap.
If it is lint, always keep the lint collector inside the agitator clean.
If it is soap, and this might work for lint:
1. Turn clothes, particularly black clothes, inside out.
2. Use a concentrated soap with little or no filler.
3. Use less soap than normal.
4. Fully dissolve soap before adding clothes.
5. Run rinse cycle again after completing full wash cycle.
Jun 22, 2011 | Admiral AW22 Top Load Washer
The whashing comes out with white powder like stuff. Can I clean the drum and if so how ? is it flint that gathers some where?
Hello Sir Tommis,
I understand that you are having a problem with your washing machine. When you wash clothes they come out with a white powder like substance on them. This white powder substance is the powder laundry soap that you are using.
This is generally caused by adding to much soap and clothes to the washing machine. The soap is not getting dissolved and the clothes do not have enough room to agitate in the machine. Try to put 3/4 of the amount of clothes in the washer with the same amount of soap and see if the clothes come out with the same powder like substance on them.
The clothes that currently have the soap on them will have to be hand washed with a scrub brush in oder to get the material off of them as running them though the washer will not remove the soaked in soap.
Thank you for choosing FixYa.com
Justin
Mar 26, 2011 | Whirlpool 3.2 cu. ft. Washer
Green whites?
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Small brown spots on whites
Nov 15, 2008 | Maytag PAV2300 Top Load Washer
Clothes smell after wash cleaned filter still clothes smell
set the machine off on a 95c wash with no clothes or soap in, the most likely cause is a build up of soap scum on the inside of the drum, also try to alternate between washing powders and liquid tablets.
hope this helps
Jul 25, 2008 | Indesit Washing Machines
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Soap residue on clothes from washing machine
I have the same problem. Can't get soap out my clothes. I have a Sears Kenmore frontload washer. It seems to work fine but something isn't right. Repair man came few days ago & said NOT to use the brands they say "For ALL HE Washers" ALL being the key word. Only use the ones that only say HE. I changed back to Gain instead of Sam's brand, but I still can't get soap out. I really don't think its the detergent. I washed my daughters towels & had soap in clothes after complete full wash was done. I'm lost & have no idea what the problem is or how long its being going on before I noticed.
Dec 15, 2007 | Washing Machines
Washing Machines Logo
755 people viewed this question
Top Washing Machines Experts
