Question about Kenmore 44102 Front Load Washer
Kenmore Elite Front Loader
Approximately one month ago the tub had water remain after the spin cycle. We removed the front panel and removed a quarter (.25c) and some other debris. It worked ok ever since...
Now it drains ok... but the following day it is filled up with water. Almost as if someone is adding water when we are not looking. How in the world could that happen? How can water come in when something is turned off?
  • 1 more comment
  • dunk428 May 10, 2009
    I am not sure I understand. If I turn off the water at the faucet then what do I check? Is there a fill valve on the hose side of the faucet?
    We turned off the water and disconnected the hose. I dont see anything more than the opening to a hose. Do I need to take the unit out in a to an open area and remove a back panel? Can you please be more specific on what I need to do. Thanx.
  • dunk428 May 11, 2009
    We took off the top panel. The two water hoses are disconnected. We removed the light blue thingy that had two water hoses attached, two filters and 4 wires. I do not see how we can get it any cleaner than it is. I dont see where there would be a valve. I guess that is what you meant when you said "You can't always take them apart". Not happy. Now what?
    Genius:
  • 1,198 Answers
Debris can be in the fill valve, jamming it open a little. You can't always take them apart. Turn the water off at the faucet to check. Get new hoses, the filters in the old ones must be bad, and old hoses can blow.
Posted on May 10, 2009
  • mike kirschbaum
    mike kirschbaum May 11, 2009
    You're making good progress! If you have nut drivers or a small socket set, the tops on the blue thingy might come off. There will be a spring and a piece of metal, don't let them fly. With the hoses removed from the blue thing, clean out the insides of the valves. Or just get a new blue thing, then you know it will be good.
Code F35 on Kenmore Elite HE5t front loader washer.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
Water pours in on spin cycle
The first thing i would check is your boot around the door for a rip or tear. Also check the drain line for any types of leaks. You can also remove the bottom panel there will be three torx screws and you can look at your drain pump while in spin and drain cycle to see of the leak located in that area.
Hope this helps _MJ_
Jan 29, 2010 | Kenmore Elite 45986 Front Load Washer
Front loader
something is restricting the draining of unit either in the drain hose, but most likely in the pump remove the bottom panel and pump is in the middle and have 2 5 gal bucket handy to catch the water when you unscrew the cap to the pump ----- unless you use your wet/dry vac to empty the tub this is the best method then only a small amount of water will remain
Aug 24, 2009 | Kenmore Elite 45986 Front Load Washer
Front loading machine abnormal strong vibration on the spin cycle
Check the tub rollers or wear plates.
May 30, 2009 | Kenmore Washing Machines
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Font loader washer water does'nt shut off
remove top replace fill valve left rear be sure not to remove the screens inside valve except to clean but be sure to reinstall or trash may get into valve and not allow proper shutoff
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Elite is making groaning noises and then error messages 5D and/or F
did you clean pump out by removing acess port on front end of pump? also you can ckd pump impeller by removing screws around pump body impeller will free wheel but should have some resistance to turning by hand if no water in tub reinstall pump put in drain spin to see if drum will spin if it does forget main motor ..motor is most reliable par on those washers
Aug 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
Nov 08, 2007 | Kenmore 46462 Front Load Washer
Kenmore 44102 Front Load Washer Logo
196 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
