Question about Intel DG31PR Motherboard
No display during boot
Monitor doesn't display anything during the entire boot up process, but seems to go into windows xp normally. Used to be working fine until one morning - nothing added in HW. Same problem on two different PCs, both Intel MBs (G33 w/ integrated graphics, P35 w/ NVidia 8600 card).
  • 433 Answers
Try a different monitor. Could be burnt out.
Posted on May 11, 2009
My GX520 pwr light is green, on the board is an amber Led, the somputer boots up, it goes the full process, until the arrow appears on the monitor. no Iconn are displayed on the desktop
If your computer gets to that stage, then I would guess you have an OS ( Operating System ) problem. Try booting from your XP installation CD. If that works then you may have to re-install Windows.
Jun 23, 2012 | Dell OptiPlex GX520 PC Desktop
Far cry 2 keeps crashing to blackscreen
When does this crashing or black screen happen? During the boot up process or while you have windows booted all the way up?
If the computer is booting up all the way except the screen is black try the steps below.
Either your monitor or video card inside the computer is bad. Try connecting another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without any problems then your video card is good, but your original monitor is bad. If the Borrowed monitor does not display then the video card inside the computer is bad.
If the computer is not booting up all the way then try the steps below.
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 07, 2012 | Computers & Internet
My Dell Dimension 8400 desktop computer using Windows Xp operating system. The monitor shows the Xp Logo at first. Then the screen goes blank about 30 seconds into the boot process. What can I do to g
If you hit <F12> key upon boot-up and the monitor displays a boot menu, then you probably have an issue with your XP software. Meaning that you may have to re-install XP (by the way, XP is no longer supported).
Jan 28, 2012 | Dell Dimension 8400 PC Desktop
Cannot display on monitor
If your PC gives single normal beep while booting then try connecting your monitor to another working PC. If it doesn't display then check the VGA cable by replacing it with new one. If the beep is not normal then tell us the beep behaviour.
Nov 30, 2011 | HP Vectra VL420 Desktop PC - Intel Pentium...
PC BOOTS HALF WAY
Try booting into safe mode. If it's a driver problem, safe mode will allow you to start Windows with only the bare minimum of hardware and drivers being engaged. To get to safe mode, press the F8 button on your keyboard during the Windows boot process until it takes you to a screen to let you select Normal, Safe Mode, Safe Mode with networking, etc. I would suggest not using anything other than just Safe Mode. From there, uninstall any software or new drivers that you recently installed. Alternatively, you can use the System Restore feature to rollback to a previous restore point.
Aug 10, 2009 | HP Computers & Internet
No graphical display during booting up of windows XP. After a while an on screen message is displayed as "High resolotion not supported" . No problem when a live CD (Linux) was used.
you might have changed the screen resolution or the refresh rate that your monitor might not support. So you better get into the safe mode by clicking the Function key 7and 8 then use the option called safe mode.
After the windows starts log in to the administrator profile, right click the mouse on the desktop then select properties. A display settings window will pop up, in that change the screen resolution to 1024X768 and bring the monitor frequency rating to 60 or 75 Hz. Now apply the settings and restart the system in normal mode.
If still the problem persist then in the monitor control select "auto adjust" to get the things done.
Aug 06, 2009 | Compaq MV 540 15" CRT Monitor
Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
Iiyama Pro 452 clicking sound during start-up
Your CRT Monitor will fail soon. The clicking sound is coming from your CRT's power circuit.
Make plans now to replace it. This problem is known to be a fire hazard in some cases. So, better safe than sorry.
Sorry for the bad news.
Hope this was helpful.
Worldvet
May 21, 2008 | iiyama Vision Master Pro 454 19" CRT...
Power Failure
If you mean the Monitor is powered by an external power supply Then that indeed is an option worth trying Simply get a multiple voltage one and set it to the voltage of the existing one. There may be internal problems such as the inverter But this will be a repair shop job.
May 22, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Intel DG31PR Motherboard Logo
233 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
