Question about Gateway 3550GZ PC Notebook
HELP! Laptop will not boot up!
When i try to start my laptop, I get a message saying: "we apologize for the inconvenience but windows did not start successfully, A recent hardware or software change might have caused this, etc.
I have tried all 5 options for starting in safe mode, with networking, command prompt, last known good config., and start windowns normally. NONE of them do anything, Windows xp logo shows up and its thinking bar scrolls along the bottom but then it always goes back to the original inconvenience messege! HELP i want to use my computer!!
  • Anonymous May 14, 2009
    i'm not sure where the Win XP install CD-ROM is... :S
  • Gateway Master
  • 4,338 Answers
Try an XP repair:
Boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 10, 2009
I had to reboot my Eee PC; however, now a message comes up statting the following: "We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might...
If you added any exta hardware means kindly remove it and boot the computer
Then you try boot by selecting the option of Boot using last known good configuration.
If the boot is successful then you can boot later booting without any problem.
If boot is not successful and this problem is happened after installing any software or driver software means boot in safe mode by pressing f8 key and uninstall it
Mar 12, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
It wont start up kind of
Try start, run, then type MSCONFIG go to start tab and UNcheck everything, then go to services and at the lower left of the window it says hide microsoft services and check the box then disable all then restart and see if that helps.
Sep 02, 2009 | ASUS Eee PC 1000H Laptop
Will not reboot...continues to go back to "We apologize for the inconvenience screen"
First, see if you can run diagnostics from the F12 menu or from the Dell Resource CD and see if the HDD or any other hardware indicates a failure. If you are having a hardware failure, there is no point in trying to fix a software issue until the hardware is fixed.
If the HDD fails diags, replace it. If it passes, then try booting to the XP CD, and see if you can boot to recovery console, and run CHkDSK /R
Apr 14, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
Sony vaio not loading windos
Try booting XP with the installation CD & use the recovery console to boot the laptop.
From the Setup CD-ROM
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD.
When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. When prompted, type the Administrator password. At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
To exit the Recovery Console and restart the computer, type exit.
Dec 10, 2008 | Sony VAIO PCV-V210P PC Desktop
Windows laptop won't boot -
Try pressing the F8 key at start up. This should take you to safe mode, from here you will be able to shut Windows down properly and reboot without the loss on any data except for what you were working on at the time of the power loss. If it won't let you do this and stays in the same loop, it could be that the hard drive crashed and needs replacing. I don't do data recovery from a dead hard drives, so I can't give you an estimate on that, but a hard drive replacement, system reload with drivers and updates will run anywhere from $150 up to $600 depending on what you want.
Jul 01, 2008 | Gateway MX6920 Notebook
Acer 4710 did not reboot
Acer 4710, also has many versions.Give me the complete model # and i can help.
Jun 10, 2008 | Acer Aspire 5500 5570-2609 Laptop
HP Pavillion ze5600 notebook won't boot up
Try booting, hit F8 for the list, go to safe mode but right after you hit enter to go into safe mode hold the left and right <ctrl> keys. That loads minimal amount of drivers as possible. Do you have you Win XP disk in case a repair is needed? Let me know what happens.
Apr 14, 2008 | HP Pavilion dv1000 Notebook
Unable to get PC to boot
Does it have a floppy drive? if so, check if there is a floppy disk in the drive.
Let me know, and we can go to the next step.
Jan 10, 2008 | Compaq Evo N610C Notebook
Gateway 3550GZ PC Notebook Logo
165 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
