Question about Toshiba 32A35 32" TV
Picture The scrren is a flat black in the portion where volume bar, menu are located. When Volume or menu comes onto the screen the picture comes on in that area fine. When the volume or menu graphics go away so does the picture
  • Anonymous Nov 17, 2007
    dead set no power
  • 71 Answers
Sorry dry solder joints this model was a disaster for this not worth repairing
Posted on Dec 08, 2008
How can I set time and volume?
These 2 things can be done using the "Menu". (You can also adjust the Volume from the Driving Screen - tap bottom left area and slide the volume bar to adjust the volume).
From your Driving screen (showing map of current location), tap on the (middle of the) screen, to show the Main Menu (on the next screen),
Look for, and tap on "Change preferences".
1. To set Time:
On the next screen, look for and tap "Set Unit". On the next screen, select (tap on TIME), and you can set (reset) the (display) format and time.
2. To set Volume:
On the next screen, look for and tap "Volume preferences". You can then tap on the bar (position) and test/hear the level of the sound. And/or you can select "Link Volume to car Speed" ... and tap Done.
Feb 11, 2016 | Tomtom One GPS
Vertical black and white bars on lcd screen
I'm not too familiar with the LG brand, but if the onscreen stuff looks fine (Volume, menus, etc.) then the panel is OK. Try a picture source other than the one you are using now (Tuner, HDMI, VGA, etc.)
1) If it's the same across all of them, then you will need to replace the main board in the TV.
2a) If it only affects one input, it could either be your video source that is bad (which means TV is OK), or
2b) that certain input port on TV is bad, which would mean you either don't use that input any more, or you replace the main board in the TV.
Sep 15, 2012 | LG M208WA 20 in. LCD TV
Black screen
busted lamp. please increase the volume of the tv even thought there is a black display. if a volume comes up then chances are the ccfl lamp is busted that is why you get black display.
Apr 06, 2012 | Vizio P42HDEA Television
Alba tv screen goes black after 5 seconds of switching it on. The sound remains however. The tv is approx 18months old.
This happened to me its probably too late for you but might help others. what i did to fix this is, I put the tv onto a radio channel (with no picture) and about 10 mins later i turned the volume down and realised the screen was still on as the volume bar showed up. so i guessed it the problem was to do with light so i went on the menu and went into features and turned the backlight onto minimum and the tv has been fine since. hope this helps!
Mar 30, 2011 | Audio Players & Recorders
I get sound on my tv but no picture. not even volume bar or menu
check to see if there is an image on the screen by putting a light close to it if ther is an image replace the backlight inverter
Jul 09, 2010 | LG 32LG30 32 in. LCD HDTV
Acer speaker?
There are two possible problems here. (1). The volume control on your monitor is turned down. With the button on the front of your monitor, find the menu/option button, and look for volume control (2) The volume coming out of your computer is low. Double click on the speaker at the bottom right of your screen, located on the start bar. Use the sliders to change the volume. This should fixya up.
Good Luck!
Dec 12, 2008 | Computers & Internet
No color
Sep 06, 2008 | Akai CTS2550 25" TV
Black bar down screen left side 12 inches in from left
this is either a circuit board problem or the panel could have a bad tab
Dec 07, 2007 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
How can i get my tv to stop automatically changing to menu screen?
What you have there could be one of three possibilities. Micro, eprom or tact switches... Tact switches are the small contact switches behind the buttons you depress to turn the volume up and down or change the channel. Sometimes these small switches can become contaminated or breakdown due to corrosion. What we call in the industry a windex syndrom, because the older crts on some models had the swiches exposed just below the lower ridge of the cry where when cleaning the screen windex could drip down onto the switch and cause the corrosion to begin.
Eprom is another likely suspect. This Ic is responsible for storing an array of information including customer settings and other logics convert what the eprom stores into electronic pulses for any number of fuctions. For example press the volume down on your Tv and the eprom has the information to show you the volume bar, the level the volume bar was last set at and the increments at which you are reducing it realtime.
The Micro is another possibility. It acts like a traffic cop engaging various circuits to do or not do something according to a preset list of conditions. Timers, looking at a particular input or yes even bringing up the menu is tasked through the micro controller Ic or micro for short.
The fact that you can eventually get the unit to operate suggests that something in the logic circuit is failing and will in all likelyhood continue to do so until eventually it doesn't work at all...
Nov 14, 2007 | Televison & Video
Toshiba 32A35 32" TV Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
