Question about Nintendo Wii Console
WII Video doesn't show up with my receiver
Hi, I have a sony projection tv hooked up with onkyo HT receiver. If I connect the WII directly to my TV it works but if I connect it via my receiver the video doesn't show even though sound is working. I hve tried with the regular cable as well as the S-Video cable. same problem.
Thanks,
-ary
  • ary_singh Oct 27, 2007
    Yea its on vid 3 man ... still not working.
    Thanks
  • 47 Answers
Make sure that you have the reciever in the correct setting.  Sometimes on them the s-vid is like video 3 or so on
Posted on Oct 27, 2007
Can I connect a tv antenna to an onkyo HT R-550 receiver? I see only fm and am. Thanks.
Hi Mark, You can't connect a TV antenna to our receivers they do not have TV tuners. Thank you, Onkyo USA
Oct 21, 2016 | Onkyo Audio Players & Recorders
No video when connecting wii to Onkyo TX-sr507 AUX
Did resolve the issue? I 'm pkanning to buy wii @ my home. Please suggest me.
I do use the Onkyo 507.
Jul 25, 2010 | Onkyo Tx-sr507 A/V Receiver
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
Hi, I am having trouble connecting my Nintendo Wii to my Onkyo TX-SR507
Take the adapter cable from the Wii that plugs into the back of the Wii and converts the output(audio/video) into RCA style pin plugs, you will have: RED=right channel audio, plug it into any of the red audio INPUT on your Onkyo, then you will have WHITE=left channel audio, plug it into the other white INPUT jack next to the red plug on the Onkyo, then you will have YELLOW= video(picture) that will go directly to the yellow video INPUT on the back or side INPUTS of your TV.
Then when you want to play the Wii, set the input mode on the Onkyo to the inputs that you connected the red and white plugs into, then change the input on your TV to which ever the input is labeled on your TV in which you plugged the yellow plug into, you now will have sound comming from your Onkyo and the Wii up on the TV screen ready to play. Good luck!
Jan 27, 2010 | Onkyo Tx-sr507 A/V Receiver
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
No sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
Jan 10, 2009 | Onkyo HT-SR800 System
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Dvd connection
Yes! You can pass the video signal through the receiver. This is most useful when you have more than one video device (e.g. DVD, cable box, VCR,...), and you can use the receiver to switch to the audio and video for the selected source at the same time.
On the back of your Onkyo HT-SR800 there is a section labeled "Component Video." It has three inputs and one output. So, attach your DVD by component cables to the "DVD In" and then attach component cables from the "OUT" receiver connection to the TV.
If your TV doesn't have a component connection, then this addresses your other question. You can't gain anything with this, because your TV doesn't support it. Connect the DVD to the TV according to the highest quality connection that they both support, in this order: composite, S-Video, component.
If you are using composite, but they both handle composite, than yes, you will get a better picture by going to component (or even S-Video). If both devices support progressive scan, this could be a substantial difference.
Your receiver accepts component, s-video and component video, but keep in mind, it may not do "video switching." So if you connect the DVD in via component, but go out to the TV over composite, then you may not get any video at all (but feel free to try). Try to avoid this, but you may be forced to try depending on the limitations of the various devices that you are hooking up.
Jan 16, 2008 | Onkyo HT-SR800 System
Connecting a Dish 622 Receiver to the HTR500 and a Sony HDTV TV
I haven't researched to actual manuals for your equipment, but I'm guessing that the optical may be disabled when the HDMI is used. You could try using the component video outputs to the TV and then the optical to the Onkyo.
Jan 02, 2008 | Onkyo HTR500 Receiver
Nintendo Wii Console Logo
316 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
