Question about Northern Industrial 2 Hp Twin Tank Electric Air Compressor
New machine fails to start
We just bought an air compressor that was used in a tool show and brought it home only to find that we couldn't get it to start.  We plugged it in and it makes a sound for a few seconds and then turns itself off.  What could be the problem?  Are we doing something wrong?  Yes it has oil and we have checked online for all the necessary things to do before start up.  (We couldn't get an owners manual, unfortunately) but Rona has almost the same machine so we were able to get a copy of theirs.  It still doesn't work.  What could be the problem?  Any ideas?
  • pulltoomuch May 11, 2010
    1. whaaaat kind of noise? hum or squeak.
    2. checked the pressure contacts for movement?
    3.elec. motor try to work?
    4. does anything try to move?
  • 1,305 Answers
A 2 hp electric motor needs usually needs a 20 amp circuit to run it. If you are attempting to run in on an extension cord, this will act up as well. Put the plug directly in an outlet and see what happens. You may have even tripped the circuit breaker on the unit.. it's on the side of the electric motor... just press it back in. Most of the household electrical circuits are 15amp circuits. so the problem may still persist. But if you get enough amperage to the unit, it should work fine...let me know what you find out.
Posted on May 10, 2009
Central pneumatic 3gl pancake air compressor 61615 the reset button pops or blows wall socket fuse any ides why? motor brush replaced and new power cord plug put on the 3 grounding prong was cut off
most likely a start run capacitor has failed
do not remove any pins of a plug as they are all need for electricity
if the capacitor replacement makes no difference , get in an electrician to test the machine and insulation
Apr 19, 2017 | Air Tools & Compressors
I have the Campbell Hausfeld WL650702RB compressor and I believe the thermal overload switch is bad. Is this a replaceable part or is it integral to the motor?
it is a replaceable part -if available-- but they are very seldom faulty
as you have not described a symptom of what brought you to that conclusion it is difficult to help you
As an indication of a problem, if the motor refuses to start, hums or does nothing , the most likely problem will be the start/run capacitor as they fail on a regular basis so check it for leaks , expanded case etc
Jan 30, 2017 | Campbell Hausfeld Air Tools & Compressors
How Do You Choose an Air Compressor for Home use?
you go by how loud it is
2 HP is a std home use direct drive motor 240 volt
with regulator
.. pump tyres . air hose .blow of benches low pressure spray paint gun a rattle gun
step up to twin cylinder belt driven compressors
trade preferred
for high daily use of air tools and spray painting..
8cmf to 10 cmf and more
can high pressure gravity feed spray gun
Oct 21, 2016 | Air Tools & Compressors
Why might my nail guns not work?
Have you lubricated either nail gun? If not, go to Home Depot and get a bottle of air tool oil. It's in tools by the compressors. Disconnect the air hose from the tool. Pour about a teaspoon of oil into the air inlet of the tool. Reconnect everything and try it 10-20 times with no nails in the tool. Then try it with nails. Good luck.
Sep 14, 2015 | Porter Cable Tools & Hardware - Others
The compressor turned on pumped up and shut off and wont start up
Inccrease the line pressure to 90 PSI, a air ratchet is a very high volume air tool and the compressor may not be able to keep up with it.
Jul 14, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor Failing? HELP!!
Portables are priced to replace and not repair unless you are an HVAC tech with your own tools and supplies. There is no guarantee you could even get the imported parts. I recommend you replace the machine; make sure you check with local authorities regarding disposing of a used air conditioner that may contain refrigerant.
May 28, 2010 | Amcor A12000E Nanomax Portable Air...
EC119SA less than one yr old just has started showing signs of low air volume. Was using it to clean off work bench, first blast of air was strong then quickly has very little pressure. The pressure gauge...
hi there, if there is enough air pressure present in the compressor the motor will stop,the pressure switch is working.if there is a good pressure at start then suddenly lost the pressure,there is no maintaining pressure to use but on the pressure gauge appear to be have a good or enough air pressure. check if the pressure gauge have enough air pressure the motor is stop,meaning the cut out limit switch stop the motor,if you loosen the air pressure from the valve until the cut in pressure attain or meet the motor will run again there will be a cycle process of differential pressure of cut in and cut out set up on pressure switch. checking the compressor,be sure there is a high pressure on compressor and the compressor motor is stop,shut off service valve and disconnect unit device / tools from the service valve. if the compressor have enough air pressure crakc down the service valve and observe the pressure until it run again the compressor motor,if the pressure maintain the pressure you need to clean the bench, the problem is the unit device/tool you use is defective, but if the maintaining air pressure in the compressor is lost due to malfuction of motor and the compressor engine. check the pressure switch, check the motor function by loosening the belt and run the motor w/o the compressor engine if it is tripping brought it to service center, check also the lubricant oil,if neccessary change oil.have a nice day and fix my rate thanks a lot.
Apr 20, 2010 | Hitachi EC119SA Twin-Stack Air Compressor...
Fan cool fridge working 3years bought new 2days ago starts blowin
Good day,
I don't understand your caption..........
Fan cool fridge working 3years bought new 2days ago... However, it sounds as if the compressor is trying to start and cannot.
If the machine is under 5 years of age, the compressor is under factory warranty.
There is a relay, capacitor, and overload which are connected to the side of the compressor after removing the back bottom rear cover.
These items could be removed and taken to an appliance parts house, where they would be glad to test them for you. Replace failed parts.
However, if it is under 5 years of age, I would recommend you call for factory warranty service. They may have to charge you for one of these parts, but since it could be a failed compressor, and not the starting components it is better to let them service it and maintain the balance of your compressor warranty.
Jan 29, 2010 | Jenn-Air JBL2086HES Bottom Freezer...
Air stapler leaks air through ''nose''
This sounds like one of the O-rings has failed. Yes it can be fixed. Check to see if HD has an O-ring kit for these guns. That kit will contain all of the O-rings as well as the lubricants for a total rebuild. That should resolve your problem.
Dan
Nov 12, 2008 | Air Tools & Compressors
Gamin nuvi 200
need to get unlock code from garmin ! they will give it to u for free !
Jun 14, 2008 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
Northern Industrial 2 Hp Twin Tank Electric Air Compressor Logo
91 people viewed this question
Top Northern Industrial Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Northern Industrial Air Tool and Compressor Expert? Answer questions, earn points and help others
