Question about Garden
Engine free wheeling,blade not turning. engine working nomal no power going to blade. Model 250R professional clearing/spacing saw
  • 155 Answers
What brand curved or straight shaft?
Posted on Jul 26, 2009
How do I adjust the blade to stay on?
Many times this is caused by worn beearings or a worn rubber "tire" on the idler or drive wheel.
Aug 13, 2014 | Saws
Blade continues to spin after turn off
I don't know the make or model of your saw but the blade brake on circular saws is controlled by the power switch. If your saw previously did brake the blade rotation, you need a new switch to make it work again. Also a generic switch will not do, you have to have the brake switch made for your saw or it will do the same thing.
Apr 07, 2012 | Saws
I am changing the saw blade on 12 inch Craftsman bandsaw
Go to: Searspartsdirect.com and enter the complete model number minus the decimal point. This will bring you a series of parts drawings and possibly an owner's manual. Generally, adjustment is provided for the upper wheel only--use hand power to check the tracking performance. Good luck!
Jan 12, 2010 | Saws
Upper wheel on a model 28-682 bandsaw. How do you adjust it.
With saw unpluged!!!!! open top wheel gaurd.Spin wheel by hand while moving the adjuster knob on back of the machine. As you turn both at the same time the blade will trac either the front or back of the wheel. Move the knob (while spinning the wheel) until the blade is tracking in the middle of the tire. (rubber strip around the wheel)
Jun 10, 2009 | Saws
I do not know how to change the blade on a dewalt
I'm not familiar with that particular band saw but I have had a few different band saws and they all pretty much work the same.
Unplug the saw and remove the top and bottom wheel guards.
Look behind the top wheel and you should see a large bolt standing vertically it may have a knob on it or it may not, look on the bolt to see if it has stop nuts if so loosen them then turn this knob so as to lower the wheel enough so you can remove the old blade.
Clean the rubber tires on both wheels and install the band with the teeth facing down.
Now the tricky part, adjust the top wheel so that it is firmly against the band and turn the wheel slowly by hand (be sure the saw is unplugged) if the band "walks" one way or another, you will have to find the set screw or set screws that adjust the tilt of the wheel, adjust these until the band runs true on the wheel. When it does, tighten the wheel a litte more and turn again slowly by hand repeat this until the band runs true and it is very tight on the wheel, Put the guards back on before you turn on the power. You should be good to go.
Apr 05, 2009 | Dewalt dw3988 14tpi portable band saw...
Band Saw Blade won't stay on
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there.  If the back guide is a roller bearing I woud think you would want to roll all of the time.  If a solid bearing block natually a small space where it  will not hit is enough.
Jan 16, 2009 | Craftsman Saws
Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Nov 17, 2008 | Saws
Ford explorer 2006
check thermostat or fan clutch is going back
Aug 22, 2008 | 2006 Ford Explorer
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
