This problem should be removed because:
Problem with Monitors
samsung syncmaster 730 b no picture
when xp did their update the other day i lost my monitor. i have no picture and the on/off light keeps blinking. i tried rebooting several times, but that didn't work. i tried a different cable and that didn't work. can you give me any other suggestions?
Suggested Solution (3)
It sounds like you have a monitor with a common problem. After a few years some LCD monitors
will blow a power supply. The problem is caused by parts called
capacitors overheating in the confined space of the monitor. If you are
good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work
fine. The capacitors do need to be installed with the correct + and -
connections, note the stripe on the old one and insert the new one the
same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Source: No display on SyncMaster 920NW after reboot from power failure
Look for bad caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Source: As I worked the monitor
Dear ,
let me know this problem you fecing in other C.P.U.?
also if you are not cheked another C.P.U.and give me feedback to me i will help you .
Monitor stuck on low resolution
Having trouble finding a page to help me out hence the post. After installing today's updates from MS (4 updates for XP Home) I...
have you heard anything about this?
posted by tedgett on Oct 12, 2007 Report abuse when xp did their update the other day i lost my monitor. i have no...
HDTV as pc monitor-no digital signal
Hello: My 24'' monitor failed and I purchased a Samsung 23'' HDTV to use as pc monitor. Although I had digital display on...
I have 7 different hortizontal lines appearing
I have 7 different horizontal lines appearing across my screen that seem to be permanent and several are a line of pixels apart. Rebooting...
My computer monitor will beep and then the Screen
My computer monitor will beep and then the Screen Resolution will automatically skew / stretch out. I have had it set for several years at...
Tips for Helping tedgett With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
appears that mensage ''OSD...
appears that mensage ''OSD LOCKED'' every 5s,how to unable that function?
how to download mixer
MY VOLUME DOESNT WORK
Fix-O-Meter
321
321 people viewed this problem
- 0 people are following this problem. Be the first!
Top Monitor Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
