Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Maxtor 3200 hard drive use to work just fine..put in storage for a couple of weeks and now it shows an error code 10 when it tries to re install have tried uninstalling and reinstalling and resetting both the computer and the hard drive..have tried new usb cable and have tried in all usb ports on computer...im assuming the hard drive is broken but thought id ask to see if anyone had any suggestions before resigning to the fact that i probably just lost everthing on the hard drive
  • Les
    Les May 10, 2009
    Hi, had a similar problem with mine, only way I could get it to respond was to take it out of the external casing and attach it to the computer direct.
    You can then get all you files off and then work on fixing it, should be no reason to loose your data
    Hope this helps
  • Les
    Les May 11, 2010
    if the drives bad as u say joecoolvette is their any reason to pay for a new ext. enclosure?
  • 5,660 Answers
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
Posted on May 10, 2009
Need to locate a working identical Maxtor 3200 200GB
Well this is not how I like to answer questions on this forum, but here is a place to start looking for your drive. I hope this helps, there are some listed.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=+Maxtor+3200&_sacat=See-All-Categories
Sep 15, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor personal storage 3200 problem!!!
First, try another USB Cable. If that does not work properly then I would suspect the box or the drive has failed. If you just bought it, return it to the store and complain. They may replace it. As for your data?
Now if you want to become techie you can remove the hard drive from the box and attach it to you computer either copy the files back if you do not have them on your computer or format the drive if you have your files. Then put the drive back in the box and try to get a refund or buy a different external. I like a metal box with an AC cord plug. Best of luck.
Jun 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I have a Maxtor 3200 USB drive. It stopped working and dont know why Has Error 10. I try to reboot computer, but everytime i do this the computer freezes. I guess the computer has a hard time figuring...
hi
please pres dell WHILE BOOTING YOUR SYSTEM GO TO THE BIOS AND BOOT OPTION DISABLE BOOT FROM USB AND GOTO THE USB SETTING AND MAKE THE USB AS GENAREC AND EVERY THING WILL BE FINE
GOOD LUCK
Jan 04, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My Maxtor 3200 ext. drive which I had for one year now (no pbs.) not being recognized by my system and I see a Code 10 error in the Device Manager.
first you can use your troubleshooter in your device manager to find out what that code 10 error is or you can go to the maxtor website in the support or troubleshoot section and tell them your code 10 error,it might be a driver needs to be updated.
Dec 05, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Code 10 on drivers
please post if you found an answer for code 10.
Sep 24, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 not working
Check for error code 10 in the Windows device manager. You likely have a power supply problem.
View my related posts on this FixYa site or on the Seagate Knowledge Base website.
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&message.id=1258
If it is a power supply problem view my FixYa post below for help finding a new power supply.
http://www.fixya.com/support/t2911563-go_about_getting_new_power_chord
Aug 29, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Cannot find hard drive
I got the same problem on my 3200. Found out that the adapter was bad. Changed it and everything worked ok.
Best regards
Trond
Aug 12, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Basics Personal Storage 3200
You need to open the enclosure and either put the drive in another enclosure or connect it directly to your computer.
Or you can pay to send it to data recovery people and they will get all the data off.
May 27, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor storage 3200
right click my computer
select manage
select disk managment
right click on the maxtor drive then select change drive leter to "L" if you like.
Apr 27, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
355 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
