Heat pump -> installing digital thermostat.
Installing the Honeywell RTH7500 series on a heat pump system. This is an OLD HOUSE and I've followed all the diagrams, yet I can only get uncooled air or heated air. My husband started working on this and left for work, now I'm stuck in a hot house and I'm pissed! Any ideas? Honeywell is closed on Sundays.
  • tachederouss May 13, 2009
    It turns out that it was partially the wires not being fully secured and the compressor still being overheated from being turned on and off too much. I fixed it myself and everything's working fine!
    Scholar:
  • 152 Answers
Sounds like the thermostat is not energizing the reversing solenoid , unless you have some experience with electrics i recommend that you call a trades person, to check this problem a multi meter is required and requires the user to know how to work with power , please do not attempt it yourself ...
Posted on May 11, 2009
  • Paul G
    Paul G May 11, 2009
    sounds like the thermostat is not energizing the reversing solenoid , unless you have some experience with electrics i recommend that you call a trades person, to check this problem a multi meter is required and requires the user to know how to work with power , please do not attempt it yourself ...
I'm installing a Honeywell Thermostat RTH2410. In Step 1 you need to identify the system type. I have a Carrier Heat Pump model FA4BNF030. Is this a heat pump with or without auxiliary/backup heat?
Auxiliary heat is electric heat that is put into the air handler on the inside of the house. Its used when your heat pump doesn't provide enough heat, but heat strips are not always used. To see if you have auxiliary heat, look inside and see if you have breakers on the front panel of the air handler or anywhere close. No breakers, no electric heat. Hope this helps!
Dec 11, 2010 | Honeywell Electronic Programmable...
New thermostat not cooling. Blowing heat instead.
Hello You have only 5 wires? multi stage if so ,is run by something else.Check that RH/RC is jumped out on new stat.Also check that O is not on the B terminal.If there is an A/B select switch set it to O.Emergency heat button dont matter as there is no wire to run it with only 5 wires.
Apr 17, 2010 | Honeywell Programmable Thermostat Heater
Installed a honeywell rth7500 series thermostate, no air
Heat/cool wires crossed. RC- is red cool make sure the batteries are good and room temp is higher than cool setting. good luck
May 29, 2009 | Honeywell Electronic Programmable...
My heat pump won't cool my house. I have a honeywell rth7500 programmable therostat. It is blowing cool air out of the outside unit and the lines are normal temp.
Warm air should be blowing out the outdoor unit. Have a technician evaluate if the compressor is functioning. There are many reasons why the compressor is not working. One of them being a start capacitor not working. Another being out of Freon due to a leak. Good luck
Apr 25, 2009 | Honeywell Electronic Programmable...
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to www.honeywell.com if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Installing Honeywell RTH7000 - I have too many wires!
check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Replace Carrier tstatccshp01 builders standard thermostat with Honeywell rth7500 series and wiring not matching Does O wire go to Aux..? fan working but no cool air.
No... Aux. is auxiliary heat strip. This is usually a white or black wire its up to the choice of the installers preferance. O or orange wire. is used to the reversing valve on a heat pump. If you do have a heat pump there is a programing section inside the Honeywell t-stat. which should say heat pump or straight cool, then another section that will ask if you want the reversing valve to energize in heat or cool. most Heat Pump brands energize in cool the exception is Rheem and Ruud they energize in heat.
May 17, 2008 | Honeywell Heating & Cooling
Installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
360 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
