Question about Amana ALG331RAW Gas Dryer
Metal screen where heat input is has sharp edges...
My Amana gas dryer has a heat input toward the rear of the tumbling compartment covered by a metal screen with 1/4" holes. There is an accumulation of dark residue and it appears that part of the screen. The sharp edges seem to be damaging the clothes. There does not seem to be a way to remove and replace this screen without changing out the entire rear wall of the dryer. Any suggestions?
  • gokings814 May 10, 2009
    If you look on the #7 rear bulkhead diagram, it is item #2 "heat duct cover". I cannot find the screw that is listed on this diagram in order to replace the part though. (part no. 503605). The diagram you referenced is very helpful though.
    Genius:
  • 1,198 Answers
Http://www.pcappliancerepair.com/model-display.php Go to this site and put in your model number. The picture I found does not fit your description.
Posted on May 10, 2009
  • mike kirschbaum
    mike kirschbaum May 11, 2009
    If you can't see the screw #3 you are going to have to get heat duct #1 exposed. That may be a real chore, I'm suprised they didn't make the screw accessable. Hopefully the drawings will help you to see how the unit comes apart. You may be able to get the part from your local dealer.
Dryer drum will not spin and there is no heat.
Unplug appliance from mains supply. Remove rear cover (Warning: sharp metal edges) and check thermal fuse with a ohm meter (multimeter). If the fuse is open circuit (no continuity) then it needs to be replaced.
Oct 13, 2014 | Kenmore 6.7 cu. ft. Electric Dryer
Dryer drum makes a scraping metal sound
bushings at edges front and back are bad front ones are long and flat rear one is a small short plastic sleeve over center shaft. requires ordering parts from manufacturer and almost total disassembly
Dec 29, 2012 | Dryers
I have a Amana clothes dryer model no NDG78700AWW. The dryer tumbles but it is not producing any heat. Any thoughts on the problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Amana NDG7800AW Gas Dryer
My Amana Heavy Duty Dryer will not heat up. It tumbles but it doesnt warm up. WE have cleaned out the the machine and the vent to the outside.
You didn't state if it is a gas or electric dryer. If gas the igniter element is bad, if electric the heating coils need replaced. Goodluck Google burdfrenzy
Nov 26, 2010 | Amana Dryers
I have the Amana LG-8219W2 Gas Dryer. It is tumbling, but not drying. Any suggestions are welcome!
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 23, 2010 | Amana DLE330RAW Electric Dryer
Dryer doesnt heat up
I have provided a checklist for both gas and electric dryers, courtesy of; www.repairclinic.com.
They also provide repair parts, disassembly diagrams, and instructions.
Firstly, ascertain that you have made a positive heat selection, then read on.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric Dryer Checklist:
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to
Gas Dryer Checklist:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Jul 14, 2009 | Maytag Dryers
Maytag performa dryer will not heat up
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
Igniter
Gas valve coils
Thermal fuse
Jul 06, 2009 | Maytag Dryers
Gas dryer flame won't stay lit
Check for a blocked vent.
Mar 12, 2009 | Amana Dryers
I have heat when I start the cycle and a few minutes later I lose the heat in a Amana dryer Model# DLG330RAW
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
http://www.repairclinic.com/0088_8_1.asp#Level1_14
Igniter
Gas valve coils
Thermal fuse
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 27, 2008 | Amana Dryers
Kenmore Elec Dryer Won't Heat up
Sounds like either a faulty thermostat or heating element. Both are accessed from the lower right backside of the dryer behind a metal door. Be CAUTIOUS, the edges can be sharp and cut you very easily. Good luck.
Mar 23, 2008 | Kenmore 65924 Electric Dryer
Amana ALG331RAW Gas Dryer Logo
576 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
