Question about Asko 24 in. D3250 Built-in Dishwasher
Asko dishwasher won't fill or pump, panel lights and heater on?
4 year old Asko D3250 just quit. No water in dishwasher, no pump noise, control panel lights normally and start button flashes like normal. When you open the door, it is hot on the inside like heater is coming on?
  • 2 more comments
  • gooface May 10, 2009
    Why would it still get hot if the heater element is blown? Another tech said he thinks it is a bad inlet water valve pump? I can replace anything on a dishwasher (i am very handy) but not good at the troubleshooting. Thanks!
    Not sure if my reply went through. How could the heater elemenet be burnt out if it is getting hot? Also, wouldn't the pump still run when you first start it for the initial drain before filling?
    The dishwasher is a D3250, 4 years old. It just quit the other day. No water inside, no pump noise, but when you open the door, it is hot on the inside. The last tech said needs a heater element. That is not making sense to me since it is heating. The control panel seems to be working the same as always. You shut the door and wait for things to start and all you get is the heater turning on.
  • gooface May 11, 2009
    I guess i would like a 3rd opinion since the first two are different.
  • 75 Answers
First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced.
Posted on May 11, 2009
    President:
  • 2,559 Answers
The water inlet solenoid is bad and you may also want to check the water level sensor.
  • 854 Answers
Sounds like you have a "burnt heating element". You need to get assistance to a qualified technician to replace this part. The heating element can blow for a number of reasons just like an ordinary light bulb. I would not suggest you attempt the repair by yourself unless you have some sort of experiance with this type of thing.
Posted on May 10, 2009
Asko 3530
Check the manual for the meaning of the flashing lights, and then look on this site for solutions to the problem. If all lights are flashing the water fill has probably overflowed into the base pan. It is usually a simple fix that is detailed in several places. Check under Asko dishwashers of different models because many have the same problem.
Jun 09, 2014 | Asko 24 in. D3250 Built-in Dishwasher
Asko d3250 pump runs continuously
I have a D3450 that was doing the same. Eventually I ascertained that there was a pressure switch that was not functioning properly. On the D3250 it was only accessible from the rear after taking off the lower panel on the back. It was a black part with a red membrane of sorts. I just disconnected its wire connector instead of replacing the part as it was rather expensive. I've been running mine machine at least 2x day for months since with no problems. Good luck! e53c3564-9255-4057-93f1-a616c7ab21ca.jpg
May 27, 2014 | Asko 24 in. D3250 Built-in Dishwasher
Asko dishwasher heavy wash light flashing and pump continually drains even with door open
The reason our Asko D3250 had this problem was because of a leak. The pump hose (approx. 2" black rubber hose - find it here http://www.repairclinic.com/PartDetail/Pump-Hose/8801409/1810263) was split, causing a leak and the blinking heavy wash light. The sensor did its job and picked up the leak.
If you're handy you don't necessarily need to call a repairman in to accomplish the work. You don't need to pull the front of the dishwasher apart. Unplug the power to the dishwasher. Take off the back bottom panel. Next, test where the leak is coming from. Place pans below the holes found on the bottom of the dishwasher. They are visible when removing the back panel and are most likely at the rear of the dishwasher. Plug the power back in then start the dishwasher. If your problem is a leak, you will easily spot it with a flashlight. After ordering and installing your part, make sure to dry all water that has settled in the bottom of the dishwasher. You can easily accomplish this through the back of the dishwasher with the panel removed. If it's still damp the sensor will continue to detect water. Once dry, start the cycle to make sure there are no more leaks before reinstalling the panel.
Aug 09, 2012 | Asko 24 in. D3250 Built-in Dishwasher
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Fault indicator on Asko D-3250 (heavy wash/ too much water has en
the float switch must be stuck the up position or water inside the pan or a bad float switch..
hope it helps.... if NOT let me know more about your problem...
Sep 25, 2009 | Asko 24 in. D3250 Built-in Dishwasher
ASko D3250 fully integrated - hotsteam/water swelling joinery
check the area of leak sounds like seals gone on dishwasher see if seal can be put back into groove posistion
Aug 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Asko d3250
First I would check the water line from the sink that is hooked up to the dishwasher.
You may have a screen that plugged up.
Also, if you have little pressure at your sink faucet, then you should check your house's water system.
Mar 04, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Overfill protection tripping
Is there water in the drip pan? My asko developed a leaky inlet solenoid, which would fill the drip pan eventually causing a failure. If the water evaporated, the washer would run. Normally, there should be no water in the drip pan.
May 01, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Asko 24 in. D3250 Built-in Dishwasher Logo
98 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
