Question about Admiral AW22 Top Load Washer
Flood Fill valve malfunctioned allowing water to run throughout the house. Stuck open, wouldn't shut off.
  • 291 Answers
To make sure did water keep coming in after washer power shut down? If so replace w. is stuck in open position
ps always keep screens in valve helps prevent this problem.
Posted on Oct 12, 2007
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
Dishwasher not filling
The water float switch, located on the inside bottom of the machine, may be stuck in the up(off) position keeping the water valve from functioning. This is a safety device that turns the water valve off when the machine fills in order to keep it from overflowing.
The water inlet solenoid mounted on the inlet valve under the bottom front may also be malfunctioning not allowing the water valve to open and fill the machine. If electricity is present at the solenoid terminals when the machine is in fill cycle, then check the solenoid coil to see if it is open(no continuity). Also, the timer may not be calling for water/ sending voltage to the inlet valve solenoid.
I would start by manually operating the water float valve a few time to see if that helps. You should hear a microswitch click each time the valve stem is moved up or down by the float. If not, check to see if voltage is getting to the float switch and the water inlet valve solenoid.
Most(if not all) machines have a safety cutoff switch which activates when the door is opened. That switch could also be malfunctioning not allowing voltage to the water inlet valve solenoid in fill cycle.
Jan 26, 2012 | Meiko Dishwashers
Cold water will barely flow into machine....already cleaned out strainer on incoming cold hose, water flows fine...however, once it hits the machine, it barely drips to fill up the washer. Hot water is...
bad water valve,the stuff you cleaned out of the screen most likely got inside the valve,another thing that can happen if you don't change the valve is that the valve can get stuck in an open position and it won't shut off and flood out your the parts store give them the model number and they will sell you the right time send the model number and brand name,good luck.
Apr 30, 2011 | Washing Machines
WM2277HW LG WASHER FE error code, but water keeps going into washer when power is off, also had to turn off water valve. How can i fix this?
you need to replace the inlet valve fe means fill error the valve is stuck open this is the most common way to flood your house with a appliance usually they get stuck shut and you cant get any water in. then every now & then one can get stuck open & if you put the machine on and go out it will flood the whole house.
Jan 12, 2011 | LG WM2688HWM TROMM SteamWasher
Hi I would like to drain the water out of my radiators so I can change the 2 zone valve on my heating system. It is allowing water to bypass so needs replacing but i dont want to flood the house. Please...
You first need to find the fill valve on your boiler and then shut that off. Then you need to find the drain off of your boiler or heat piping and get a hose on that. If you have a drain on the piping that is lower than the zones valve that would work the best so you dont need to drain the boiler also. Run the hose to a drain which needs to be lower than your piping oor boiler. You may have to open thebleeders on the radiators to let air in for them to drain completely. This can take a long time on some systems. You may also have to manually open the zone valves to get the pipes to drain completely. You can then change your zone valves and then open the fill valve to refill your system. Make sure that you bleed all the air out of the radiators after refilling or they will not fill completely and have diminished heat output.
Nov 14, 2009 | Plumbing
Maytag washer - the water will not stop running
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to. the another possible fault can be ------------ The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Jul 13, 2009 | Maytag PAV2300 Top Load Washer
Cold water will not shut off
Need to replace inlet valve assembly, one of the solinoids is stuck open or got overheated. Getting to the valve depends on the make of the unit.
Apr 26, 2009 | Washing Machines
Hot water runs even with the power off
strange...however, I think there is something stuck in the valve keeping it open.  If you can't fix it replace the valve assembly.
Mar 30, 2009 | Roper RAX4233PQ Top Load Washer
Hot water runs constantly - overfills
Jan 11, 2009 | LG WM-2277HW Front Load Washer
Ice maker flooded the house
how much water we talkin here a cup or gallons?? the icemaker will only call for water after dumping cubes,SHOULD at least, if only a cup of water or so id say the ice maker has an issue and needs replacing(its an entire module), there is a valve behind the machine energized by the ice maker, if htat got stuck open in which case water continued to flow overnight i would repalce both ice maker and valve
Mar 01, 2008 | Whirlpool GD5SHAX Side by Side...
Admiral AW22 Top Load Washer Logo
90 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
