Black borders on either side of creen
I have a black border on each side of my monitor screen. when i went to e-mail, it all doesn't seem to fit. please help
  • coyhawkred59 May 20, 2009
    hi all- mondo thanks. it worked!itworked!itworked! martha
  • JDTec
    JDTec May 11, 2010
    For XP:
    Check the resolution on your video:
    Start>Control Panel>Display>settings.
    You should see a slider .slide it to the left to a lower resolution.
  • 3 Answers
Is it a laptop or desktop?
If laptop, check it's not in 4:3 mode Usually pressing the FN and one of the "F-keys" does it. The key will have an image that shows the borders like on your screen.
If it's a desktop, check in your display settings. have you got the resolution set correctly?
Posted on May 11, 2009
Borders on external monitor after Dell Latitude D630 wakes from sleep
Thomas Motley,
Your monitor is displaying like it is because the graphics card refresh rate has changed. Check that the display driver is correct for your graphics card and that you are not using the generic windows driver. If the driver is correct then look in desktop properties, settings, advanced, monitor and check that the refresh rate is correct for you monitor.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 27, 2013 | Dell LATITUDE Computers & Internet
Well i have a 23 inch LG monitor and im using the recommended resolution of 1920 x 1080 and its not fitting the screen. therers 1 inch black border on tob and bottom and 3/4 inch black border right and...
Dear User,
Good Day!
Please use the auto button in you monitor then it will automatically adjust the resolution of your screen. Please feedback us what happen.
Thank you...
Apr 16, 2011 | Computers & Internet
Computer screen isnt working properly
Hi, Lady
I am Sandeep could you please let me know the exact issue, Are you not able to see the clear pictures, text , blurr images, Font size is big, Black border around image or Black border at all sides of the screen,
Please let me know the exact issue and marka mail to my E-Mail address, I am an Hp certified technican,
With regards,
Sandeep.
raigirisandeep@yahoomail.com
Feb 15, 2010 | E-Machines eMachines Desktop PC
Remove cover from HP w2408h monitor
pop the roundish 'HP' cover of the back of the stand. Remove the 4 black screws and the stand comes away. The case is just a clamshell affair, the main piece is the rear cover, the LCD front plastic border locks into it. The screen with components mounted is sitting loose in the back cover once the front border is removed. The trick is to pry off the front border without damage. Hook the fingers under the border where it lays against the LCD screen, wiggle, pull, curse and do it again. The top and bottom borders come loose easier than the end borders. Once these are popped free, stand the unit on end between your knees and pry away the end borders. A wide putty knife slipped between the border and metal frame will save your fingers but don't damage the screen. When the front border is off, lay the unit face-up on a table, undo the screws for the control panel and power switch modules, flip it over and lift off the back panel. Everything is under a metal casing.. I had no voltage from the power supply, trying to find a Fairchild chip SG6902SZ on the small control module, P/N ILTR-003, else the Pwr Bd, P/N ILP-004..
Jan 05, 2010 | HP w19 19" LCD Monitor
Screen resolution change = black border around small screen
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Dell Inspiron 8200 Notebook
RIGTH CLICK THEN DISCKTOP THEN PROPERTIES,DESPLAY AD SETTING, CHANGE INTO 1024 BY 768 PEXILS.... TO FIT THE SCREEN RESOLUTION 32BIT ONLY
Jun 04, 2009 | Dell Inspiron 8200 Notebook
Sometimes when I change the settings profile from "User" to "Graphics," a black border appears on the screen and some of the viewing window is off the screen. Usually when I click the "Graphics" profile...
All LCD displays have an "Auto" button press it and see if that fixs it. should be aparent what it does if it does it. but basicly it alines the picture with the screen. when you change back to user profile you may need to press it again.
Dec 21, 2008 | Acer AL1916W 19" LCD Monitor
I have a 1 inch on the left and right side how do I get full scre
if you hav a monitor separate from your computer(not a laptop)then just use your settings on the monitor untill it works again the way you like it..
or for laptops and monitors with no controls on them go 2 control panel>>>>appearance and themes>>>>display. then click on the tab that says settings. go 2 advanced and the dpi setting should be set at 96....and if nothing changes go 2 the appearance tab then 2 advanced. and at the bottom for the item look for active window border and the size should say 1. if it does then keepo trying to make the number bigger so your page doesnt have a black border
Nov 30, 2008 | Gateway Computers & Internet
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Black borders
Check the resolution settings on your cable box, you may have to call your cable provider to find out how to get into the settings menu, there is a stretch function in the settings that should make all the lower channels auto fit your screen, also see if there's a p=size button on your remote control, try pushing that when on the channels that have sidebars.
Oct 26, 2006 | Samsung SP-S4243 Television
Computers & Internet Logo
173 people viewed this question
David Payne
David Payne
