Where to buy a pca for hp laser jet 11P + - Office Equipment & Supplies
    President:
  • 987 Answers
I received error code 52.00 on my HP printer, what does it mean?
Laser scanner start up error.. First of all need to find out which scanner faulty out of two..
Go to menu scroll to diagnosys, scroll to component test, scroll to scanner test....
If the cyan or black component tests showed a startup failure,
reconnect the connectors (J503) on the laser PCA and (J106) and J111) on DC controller PCA... replace the scanner
If the yellow or magenta component tests showed a startup failure, reconnect the connectors (J501) on the laser PCA and (J106)..Replace scanner..
Before starting better to download service manual to better understand the replacement..
Jul 29, 2015 | HP CP3525N Color LaserJet Printer
52.0 scanner error
Try the toner cartridge first, it could be not opening properly, after that it will be the laser scanner assembly.
Mar 02, 2015 | HP P2035N LaserJet Monochrome Printer
How to solve the hp laser jet 52 scanner error
there are three usual faults that cause this
1. the scanner is unable to locate home position- remove the scan glass/ clean and lubricate all rails
2. the ribbon cable has open circuit on tracks- replace the ribbon cable connecting the scanner to printer
3. the printer main PCA has failed and cannot control the scanner- replace main PCA
Dec 17, 2013 | HP LaserJet 3055 All-In-One Printer
How can you fix 58.04 cp3525dn laser jet printer hp?
58.04 ERROR
To continue turn off then on
The low-voltage power supply has
experienced an error.
1. Check the connector J1143 on the DC
controller PCA.
2. If the problem persists, replace the low voltage
power supply.
Sep 11, 2013 | Office Equipment & Supplies
Error code 52.00
52.00 = laser/scanner error
1. Turn the device off, and then turn the device on.
2. Reseat the connectors between the laser/scanner and the dc controller PCA (J801 and J321).
3. Replace the laser/scanner assembly.
4. Replace the dc controller PCA.
Jul 12, 2011 | HP LaserJet M5035 MFP Printer
Morning printer read error 57.04 this is hp laser jet p 4015x
57.04 ERROR means that Fan FN101 has experienced an error (Fan FN101 is at Left side, toward the rear)
To continue turn off the printer and then on
HP recommends the following steps for trouble shooting: -
1.Inspect fan FN101 to determine if its rotational movement is being obstructed.
2.Verify that the fan connection at connector J64 on the power supply PCA is securely seated.
3.If the error persists, replace the fan
HP 4015 Service Manual
Refer Chapter 7, PG-286 for additional details
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 14, 2011 | Office Equipment & Supplies
C6380 - Ink System Failure 0xc19a0023 error message Just want to let everyone know i will never buy another hp printer again, i hve never had so much trouble with a printer, how can a printer only last 8...
as far as ink jets go i agree with you HP are pretty bad. However the HP color laser jets are second to none in my opinion. I work at a health care company and all we sell are HP laser jet printers. Sure the toner cost more money up front but page for page it's actually cheaper than having to buy all those ink jet refills. If you must have an ink jet printer I would try either a epson, cannon or lexmark. HERE is a good link to ink jet printer reviews
Apr 24, 2010 | HP Photosmart C6380 All-In-One InkJet...
Laser jet 3055 scanner error 6
Generally, Error 6 is a failure of one of the PCA boards and the unit requires service.
Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
HP 4550 Color Laser jet reports no "errors" yet does not print
HP 4550 Color Laserjet Printer - Blank or white pages :
01. Your software application is sending an extra page-eject command.
02. Check the software’s printing configuration information. There is a problem with the network configuration.
03. Some sharing devices on networks may generate a blank page as a separator.
04. Check with the network administrator.
05. The printer may be feeding two or more pages at once because the paper is difficult to separate.
06. The sealing tape has been left in the toner cartridge.
07. The toner cartridge is empty or defective.
08. The laser scanner door does not open properly.
09. Remove and reseat the toner cartridge.
10. Check the laser scanner shutter door for proper operation.
11. The toner cartridge guide is damaged,
improperly positioned, or missing.
12. There is no transfer roller voltage.
13. Perform the Half Self-Test Functional Check to check all other electrophotographic processes.
14. Replace the transfer roller if necessary.
15. The high-voltage connectors are mounted on the high-voltage power supply (HVPS) PCA and protrude into the toner cartridge cavity.
16. Check the springs for functionality. Clean if dirty; replace if defective or missing.
The HVPS PCA is defective.
17.The DC controller PCA is defecti  There is no drum ground path.
18 Check the drum ground.
19. The laser scanner cable assembly is defective
20 The page length and margins are not set correctly for the paper size. Verify that the ribbon connector at J1307 of the HVPS is
properly seated.
21. If the HVPS has been removed recently, verify that the ribbon connector from the DC controller PCA to the HVPS is properly
seated at both ends..
22. Verify that the photoconductive drum is rotating properly. Perform is the drum diagnostic test to visually observe if the drum is rotating.
23. OR using a felt-tipped marker place an index mark on the edge of the drum outside the image area. Turn on the printer (wait for
drum rotation to occur), and then look to see if the drum has
24. moved. If the drum has not moved, investigate the mechanical
and electrical drum rotation circuitry and movement mechanisms.
25. The imaging drum shutter may not be retracting. Replace the imaging drum.
26. Lst but not the least, please fry to have the Printer int the Setcie
27. Use only HP Authorized Genuine catridges only
Jul 21, 2009 | HP Color LaserJet 4550 Printer
I have HP 5000N Laser Jet print with "Close Top Cover" Error Message. I check (SW401) switch on and replace Terminal PCA (RG5-3560) and change/ check DCC Controller board(RG5-3517). I have check all my...
This may sound dumb but since you have another machine and have tested the switch and changed boards...have you tried swaping the top cover. I don't have a machine to look at or a very good picture but as I recall the part that activates the switch is on the cover maybe broken off or bent.
Mar 05, 2009 | HP LaserJet 5000dn Printer
55 people viewed this question
k24674
