Question about Gaggia Titanium Espresso Machine
Espresso gaggia titanium. Water Tank leaking
Espresso gaggia titanium. Have owned for 2 years. I love it.
Problem: Lately, water is leaking out of the water tank through the bottom. This is where the water is supposed to come out from, but it's not supposed to come out when machine is idle. We know it is the water tank leaking because it is removable and so when we sit it on the counter, it dribbles out.
Suggestions?
  • Anonymous Mar 23, 2014
    water is on counter after it sits a while
    President:
  • 1,618 Answers
The o-ring on the bottom of the water tank is either missing or not seated properly.
Posted on May 11, 2009
Gaggia Titanium SUP027 YDR Syptom: Displays Fill water tank even though the water tank is full and freezes the operation of the coffee machine
Be sure to check the float in your water tank. It looks like this: http://www.cerinicoffee.com/item.asp?PID=1318
If the float is not floating then you need to replace it.
Jun 05, 2011 | Gaggia Titanium Espresso Machine
Cannot solve "Ventilate" problem - weater circuit is broken
Turn the knob on after you press the hot water button, run the cycle until the message is gone takes a few seconds or about 2 ounces of hot water.
May 02, 2010 | Gaggia Titanium Espresso Machine
My Gaggia Titanium machine says ventilate
Run about an ounce of hot water from the wand.
Nov 10, 2009 | Gaggia Titanium Espresso Machine
Gaggia titanium espresso ventilate is on the screen.I press button 26,nothing happens
Hi
When you push the water button, then open the steam knob. This will allow water to flow. If you don't get water to flow check the water tank and make sure that it is down on the machine completely. The other thing that will not cause water to flow is a restriction in the flow meter.
Nov 02, 2009 | Gaggia Titanium Espresso Machine
Fill water tank message appear even when tank is full
Check the float in the water tank,it can stick or leak water and sink to the bottom.
Jul 17, 2009 | Gaggia Titanium Espresso Machine
Fill Water Tank But Water Tank is Full
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Jan 14, 2008 | Gaggia Titanium Espresso Machine
Gaggia titanium
John, The duration of the rinsing cycle is equal to the amount of water you have in the water tank. I don't believe they tell you this anywhere in the manual! I own a Titanium SS and it rinsed and rinsed and rinsed the first time I performed it! I figured out it will just keep going until the water tank sensor tells the machine it is out of water which is equal to saying to it: "Thanks for using all the water i wanted you to use to rinse, now you're finished." Hope this helps, Tony.
Dec 08, 2007 | Gaggia Titanium Espresso Machine
Gaggia titanium leaking water underneath
i had this same problem. the solution is simple if you are a little bit handy.
there is a bad valve inside. i called Whole Latte Love where i bought the machine and ordered a Steam Valve complete - Compact Frame
its part number GA-%0345.R and two O-Rings
the valve that comes with the machine is plastic and the new one is a brushed metal casing. my guess it will last for 10 years!
two screws on the back and the machine is open
near the front, by the steam wand, with a hose attached coming from the heater, is the valve, attached to the knob on the side
two more screws and the valve wrapped in a plastic housing comes out.
open the plastic housing, remove the insulated hose to the steam wand and the water/steam plastic hose that comes in. replace the valve, hook up the two hoses, but back in housing and you're done. attach back to knob on the outside, put back together and in 30 minutes, the Titanium is like new. no leaks.
it sounds daunting but is pretty easy and beats sending the machine back for repair. i can't go a morning let alone a month without coffee from my Gaggia. once repaired, the coffee is hotter too.
Nov 30, 2007 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
515 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
