Question about McCulloch Garden
Chain came off
Chain slipped off and I can not figure how to put it back on. This is a electric chain saw.
    Brigadier General:
  • 4,088 Answers
Pull side cover at rear of bar--clean everything including cover with compressed air including air vent holes around the motor case. Pay attention to two small holes in bar (one on each side) which deliver oil from motor frame to the chain slot in the bar. Only one hole is used at a time depending which side up is used when installing the bar. Lay the loose bar on a flat surface to see if it has been bent sideways (it will rock back and forth). Do the same with the chain (remove any cross-over loops). Replace one or both if apparently bent. Check original chain for any lengthwise looseness and check sprocket which drives the chain for excessive wear on teeth. Run the saw without bar and chain for short time to see if oiler pumps oil out of port. If everything looks ok, thread the chain onto the sprocket with teeth cutting-edges pointing toward the case on the bottom edge of the bar. Fit bar into extended chain and work under-side of chain into the bar slot all the way around (except rear of bar), then extend bar to pull chain fairly tight. Next, fit cover to case ensuring that adjuster tang is in the proper hole at the rear of the bar (may have to turn adjuster screw CCW several turns) and fits flat to case. Install bar holding nut(s) hand tight, and then adjust chain adjuster CW until chain holds tight to under side of bar, but still free to turn chain by hand. Tighten nuts firmly and recheck chain. Put some oil into small holes near tip sprocket (if any) to lube sprocket. Finally, run saw with chain tip near paper or cardboard surface to check for slight oil line appearing off of the running chain. Check and resharpen chain teeth if required.
Posted on Jul 08, 2009
Remove side cover of chain, loosen bar nut, there is a screw on the front of the saw under the sawdust and oil. Turning it one way tightens the bar. The other way loosens it. Loosen it til you get the chain back on, then tighten it til there is about 1/2" slack in the bottom of the chain between it and the bar. By the By, semi tighten the nut before any major adjustments, then adjust the chain to above and tighten bar nut. You should be set to go. BE CAREFUL! Dont forget personal safety!!!
Posted on May 10, 2009
2 Suggested Answers
  • 2239 Answers
SOURCE: I borrowed a friend's POULAN 14" ELECTRIC
Remove the side cover nuts and the cover, wind the bar adjuster screw fully back, it may be in the cover, or on the front of the saw, push the guide bar fully back toward the sprocket, loop the chain ocer the sprocket and lay it around the the guide bar, make sure the cutters on the top of the bar rail are facing away from the saw, this will make sure it is the correct way round make sure the bar adjuster pawl is engaged into the hole in the bar, if the adjuster pawl is in the cover, replace the cover making sure the pawl engages into the hole in the bar, refit the cover nur finger tight, adjust the adjuster screw so as the chain fits snug fully around the bar, loft the nose of the bar and fully tighten the cover nut, with a gloved hand pull the chain manualy around the bar to make sure it is fitting in the rails and the sprocket correctly.
Posted on Sep 01, 2011
I put the bar & chain on, the three hole line up easily but how do i get the brake back on the clutch?
The proper sequence to installing the chain should be to first ensure the brake is in the 'unlocked' position then loosen the chain adjustment screw, slip the chain over the back of the sprocket, align the chain with the bar, slip the bar onto the bar mounting studs ensuring the adjustment pin slips into the appropriate hole in the bar. Then slip the outer chain cover over the bar studs, elevate the front end of the bar and tighten the bar mounting nuts to 'snug'. Adjust the chain tension to the desired setting ensuring the front of the guide bar remains elevated, then tighten the nuts to secure the bar.
Remember to unlock the brake BEFORE removing the bar and chain because it is so much easier to unlock it mounted on the saw if yours is the design that comes off with the cover. If yours stays on the block of the saw and the blade is removed you have to secure the saw on the workbench or on the ground and unlock the brake just like you would with the bar installed.
Keeping the front of the bar elevated during assembly and adjustment of the chain will keep the chain tension correct for a much longer period. I hope this helps.
Mar 03, 2015 | Garden
How do I put the chain back on the electric chainsaw
Remove the cover over the sprocket. There should be a screw that has a pin on it that fits into a hole in the bar. Turn the screw to move the pin towards the rear of the saw. You have moved the pin far enough when you can slip the chain onto the bar. Place the cover back on the saw and tighten the cover so the bar can still wiggle up and down. Turn the screw the screw to move the bar forward till the slack is removed. Put on some gloves and you should be able to move the chain around the bar. If you can not the chain is too tight.
Feb 22, 2015 | Electric Garden
The chain on my 18" ryobi electric chain saw came off. how do I put it back on>
  • Unloosen the bts on the chain cover, remove the cover, loosen the bar for some slack, reposition the chain and reverse the opertaion. Be sure the teeth are going in the correct direction. Tight the chain so a dime will just slip under the chain itself.
Oct 07, 2014 | Ryobi 18-inch Electric Chainsaw Chain Saws
How do i Tighten chain
Jo:
Unplug the saw.
Lay the saw on it's side so the chain and bar are up (lay it on 4X4 blocks or something similar so the motor housing doesn't make the saw rock back and forth) Loosen the two 1/2 or 9/16 nuts... don't take them off, just loosen them a turn or two. Look toward the saw where the bar comes out (the front of the housing where the blade comes out). You will see a small screw head. Turn the screw clockwise (as if you were tightening it) As you turn that screw, the chain will tighten. Put on some gloves and pull the chain around the bar (as if the saw was running, but you are the motor). The chain should move with a little resistance. Pinch the chain at the top-middle of the bar and pull the chain up away from the bar. the chain should pull away from the bar no more than 1/16 to 1/8 inch. If you look carefully between the bar and the chain, you'll see the dogs that run in the groove in the outside circumference of the bar. None of the dogs should be fully exposed when you pull up on the chain (in other words, None of the dogs should come completely out of the bar's chain groove when you pull up on the chain. Now, tighten the two nuts on the back of the bar. Snug them down good... if the bar slips on those two nuts, the chain will come off while you are cutting.
Good luck
May 24, 2013 | Remington Electric Chain Saw
Aug 31, 2011 | Poulan 14" Chainsaw
Bought a Homelite 14" electric chainsaw. After
I am not sure if you have figured out how to put the chain back on your saw or not, but it doesn't take long.
1. Remove the plastic yellow "T" shaped nut on the right side of the saw (towards the front of the motor housing)
2. Remove the black plastic housing that covers the rear section of the bar and chain
3. Place the chain back onto the bar making sure it is facing the correct direction.
4. Place the chain over the rear sprocket area
5. Turn the +/- yellow plastic knob (towards the back of the saw on the right side) in the - direction until the metal guide inside the plastic casing lines up with the hole in the chainsaw bar
6. Replace the black plastic housing and slightly tighten the yellow "T" shaped nut.
7. Now turn the +/- knob until the chain is tight. Once the chain is tight, turn the "T" nut until it is tight and you are ready to cut again.
Jan 30, 2011 | Homelite Consumer Products 9.0 Amp, 14 In....
My saw threw a blade . I took it apart to put the blade back on I have tried everythingbut the blade ,which is the proper one isI about 1-2 links too long. this is w/ the tensioner all the way out. Any...
I would say that it's time for a new chain. After using for varying periods of time the chain will stretch too far to be used anymore. This is caused by heating during usage. Some things that will cotribute to chain wear out are insufficient bar oil, dull chain or just every day wear. I think if you get anew chain you'll be fine. When I'm tensioning my chains I run the saw at high rpm for a couple of mins. Shut off and grasp chain by mid-point of bar and lift up. I try to get enough space to slip a nickle between bar and bottom of chain. You should check tension often, as over tightening also adds to wear on chain and motor. Hope this helps you. Thanks
Nov 14, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
How to replace the chain?
Look on the side of the saw, where the blade/chain enter the plastic case. You will see a nut in there. Loosen the nut, then push the bar backwards towards the saw. It will put slack in the chain and you can pull it off the sprocket/clutch in there. (Use a screwdriver if you can't reach in there with your fingers) and wear gloves... even a dull chain can gouge you if your fingers slip. Once it's off the sprocket, then just pull the whole chain off. To install the new one, put it around the sprocket, make sure the chain guides are lined up with the groove in the bar and on the tip of the bar, then pull out on the bar (away from saw) to take the slack out of the chain. Holding the bar firmly to keep the tension on the chain, tighten the nut again. Bada-bing you're done. Should only take about 5 minutes to change it.
Jun 28, 2010 | Remington Electric Chain Saw
I was using my Remington 14'' limb N' trim chain saw and the chain slipped off. How do I put it back ??
First, inspect the chain for bent links or other damage. If ok, loosen the bar mounting nut(s) and turn the tension adjust screw CCW until the chain can be passed over the sprocket, then threaded over the far end of the bar. Make sure the chain cuts toward you on the bottom. Turn the adjusting screw CW until the chain begins to tighten. Proper adjustment is when the lower run of chain doesn't droop from the bar, yet allow easy movement of the chain by hand. Tighten the mounting nut(s) and recheck the chain adjustment. Pay attention to chain droop and readjust as needed during use of the saw. Make sure it is being properly oiled by running the saw in front of a piece of cardboard for several moments--it should throw off a thin line of oil. Hope this helps!
Mar 21, 2010 | Remington Electric Chain Saw
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
Garden Logo
183 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
